Trans fluid loss after lifting the cab
~3 months ago the dealership put ARP studs, replaced both coolers and the turbo under waranty. They lifted the cab to do it How much transmission fluid do you think was replaced? The level was full when I got it back.
Thank you |
1 - 2 quarts, only fuild that is drain is in the trans line and cooler.
Would they have to remove the lines to the bypass filter? |
THe only lines they need to disconnect is the ones up front that go from the frame to the cooler thats the only spot. As for the bypass we dont do it only the spot I said.
