no start again - Ford Powerstroke Diesel Forum
Old 09-22-2010, 02:44 PM
no start again
Dealer replaced the injector control module in may, the ficm in August,oil cooler 1 week ago. Now its cranking but not starting. Towing back to the dealer in the morning. What are the chances the ficm is bad again.? What kills this thing and is there anything I can do to prevent it? I hate having a truck I can't count on. Its an 06 no tunes, no cat kn air filter oil bypass.
Where is the ficm located? This is my first diesel.
Old 09-22-2010, 04:14 PM
Could be the STC fitting...
The FICM is on the driver's side valve cover
Old 09-22-2010, 04:16 PM
ADMIN AND TECH
could a ficm be bad already , doubt it , more like newman said , possible high pressure oil leak internally in engine
Old 09-23-2010, 02:06 AM
Will there be any codes for the stc fitting or internal hpop leaks. Where do you check the voltage on the ficm?
Can hpop leaks or bad stc cause the ficm or ipr to fail?
Old 09-27-2010, 03:13 PM
Do you have access to a scan tool?
Old 09-27-2010, 03:31 PM
Dealer had it for 2 days .no codes and could not get it to repeat. It started every time they tried it.They did not do an air test on the oil side. That is what I suspect, an oil issue. Can this be intermittent?
Old 09-28-2010, 02:17 AM
Drivin the 6.mOney pit
Feedback Score: 6 reviews
Like stated above..possibly the STC fitting...especially if you dont have the newer one piece STC in it...those older styles were NOTORIOUS for failing which causes a no start or just leaves you stranded in the middle of your trip..
Old 09-28-2010, 08:46 AM
would the front of the truck being lower the the back while parked be a symptom of the stc? Twice today it long cranked before starting rough then smoothing out.
Old 09-28-2010, 10:35 AM
Slacker
Feedback Score: 4 reviews
No, vehicle height has nothing to do with the STC fitting on the HPOP. It definitely sounds like a high pressure oil leak and just based on the behavior, I would suspect leaking dummy rail plugs or the STC fitting. Get it scanned so you can see ICP and IPR when you are having the rough start.
Old 09-29-2010, 06:09 AM
What ICP and IPR are you looking for here?
Will a bad STC fitting cause a no hot start problem, or a no start no matter what the temp?
How about the HPOP - can it slowly die, or does it either work or not work?
