x Code Front Leaves - Ford Powerstroke Diesel Forum
Old 09-21-2010, 08:55 PM
x Code Front Leaves
Does anyone know if putting X code leaves on the front end of my F350 will cause the front end to be off center. I know with most lifts it does I am just curious if by chance this will eleviate that problem....most likely not.
If anyone has put them on their rig let me know what you think. My goal is slightly more level stance with minimal extras.
Thanks
Thad
Old 09-21-2010, 09:07 PM
BOSS LEVEL
as of this moment, are you on stock springs? whats your spring code on the sticker?
im about to upgrade to x codes my self since mine are worn. and i have v codes.
Old 09-22-2010, 08:45 AM
Feedback Score: 5 reviews
Since X codes will lift aprox 1.5-2" it will shift the axle 1/2-3/4" so to get the axle recentered you need a adj track bar. We have 2..DOM or Billet Aluminum. You should also get longer shocks..Bilsteins IMO.
Cary
Old 09-22-2010, 08:12 PM
Jarrod
Not sure. Fairly certain that they are not X codes since my front end sits pretty low. Have no way of checking since I am a few thousand miles from my rig right now. Will check when I am home in a few weeks.
Cary
So it seems that I will need a new adj track bar regaurdless. I am thinking I will go the route of having the x codes, adj track bar and possibly some new shocks.....
Thanks
Thad
