FICM Question - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-21-2010, 05:02 PM Thread Starter
FICM Question
My buddy(Ford Certified Diesel Tech) came and put his diagnostic equipment on my truck. The FICM showed voltage of 36.2 and a bad icp sensor. I took the ficm off and it shows a date of January 28, 2008. Could an ficm go bad in two and a half years. I took It apart to do the repair procedure but all the solder joints look good. Do i just need to resolder and check voltage again or is there anything else to look for. BTW my buddy is out for a while or I would ask him. Thanks In Advance
Eric
2003 F250 6.0 PSD SCLB Stock 2wd
ylpj01 is offline
post #2 of 2 Old 09-22-2010, 07:39 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yes the FICM could go bad in 2.5 years. The heat induction strategy that Ford implemented to try and get around the injector stiction problem eats FICM's. You should resolder all of the stuff in the repair procedure. Not a guarantee that it will fix it but it has fixed a lot of them. Another problem is the components used in the FICM are barely up to the task.
RIP Mitch
the Org crew
PGreenSVT is offline
