Issue While Greasing Front End - Ford Powerstroke Diesel Forum
Old 09-19-2010, 04:41 AM
Well I was greasing all the zerk fittings on the front end of my truck and on one when I put in a couple pumps the grease started coming out from under the seal? It was the one that's attached to the pitman arm. My question is, is this bad? The rubber isn't cracked or anything. It leaked out a bit and that was it. I wiped off and went about my way...
Old 09-19-2010, 05:42 AM
Lt. Negativity
mines has been busted for ooo idk 3 yrs or so. I just put grease in it and roll with it dont have any problems.
Old 09-19-2010, 06:23 AM
Yea I didn't notice anything was wrong. I just didn't know if this was normal or not. I'll do the same, when it becomes a problem I'll change it out. Can't cost to much to do, parts wise...
Old 09-19-2010, 06:25 AM
Lt. Negativity
I believe it is, you'd have to replace the whole bar itself, I think I cant remeber think maybe thats why I never replaced it.
Old 09-19-2010, 07:20 AM
Weird, my truck doesn't have any grease fittings. Is that an '03-'04 thing?
Old 09-19-2010, 07:35 AM
mine has 2 zerk fittings on the 4X4 universal joints on the knuckles. My friends 03 has them on the steering ball joints, i do not.
It is normal for them to leak
Old 09-19-2010, 08:06 AM
Powerstroke Techie
That's perfectly normal for them to leak a little grease when they are greased. And yes you can replace just the drag link end at the pitman arm by itself.
Old 09-19-2010, 01:07 PM
Thanks, that's what I thought. If it gets any worse then I'll change it out...
Old 09-19-2010, 01:10 PM
just put enough grease in till the point it starts to come out.
Old 09-19-2010, 02:03 PM
Here is what my passenger side looks like, notice the two zerks...
I'll get the driver's side here in a few.
