my wonderful luck....
after reading some here I guess I know already, but I am just looking for some confirmation.
I had starting issues right at the beginning of summer, took it to the dealer and the dummy plugs were replaced under warranty. Problem solved. Started having problems again, took it back to the dealer the week of July 4th and the FICM was bad (which I had to tell him to check because I was pretty sure that's what it was the last time when the did the dummy plugs), they "checked it thoroughly this time" since I just had it there a few weeks before and said the EGR cooler was bad as well. They replaced the FICM, EGR cooler, changed my oil, glow plugs, reconditioned the turbo all under warranty (minus my $100 deductible). Went to pick it up, and after getting in it to drive off noticed the check engine light was on, service writer said it was a harness that was bad... replaced it the next day and said to come pick it up (did not notice anything about a harness on the repair ticket though). Whatever, it was all fixed and under warranty with no lights on the dash. Problem solved. Probably unrelated and just my luck, 2 weeks ago my alternator went bad. Replaced the alternator myself and noticed the coolant level was low, not much at all just noticed it from the markings on the degas bottle and dried white splatter droppings all over the area. Filled it back up and didn't think much about it since the alternator and new batteries were on my mind. Now this week my truck runs like crap when its cold in the mornings, feels like its missing or out of gas.... until it warms up. Then it runs fine. I hop on here and read about 3 threads with the same exact problem. So I guess I am on my way back to the dealer this week, my question is... oil cooler? EGR cooler already broken again? What should I tell this guy to look for when I take it back to him and tell him its F***ED UP again? I am almost at the end of my warranty and I want to make sure they fix the damn thing so I have enough time to save up enough money to fix it right after the warranty expires. |
Check the link in my sig.
you have stiction. It's easy as hell to solve. Don't take it back to the dealer. Rev-X oil additive Or just change your oil to T5 10w-30. Again, read the thread. TONS OF INFO |
I agree with obsidian. I would also remind you to flush out the Ford Gold coolant , clean the system and replace it with Rotella , Fleetrite, etc etc ELC and add a COOLANT FILTER. You didnt mention whether the oil cooler was rebuilt and cleaned while they were in there replacing the EGR cooler. I hope you are aware that the EGR cooler typically fails because the oil cooler coolant passages are restricted with debris.
^^ what he said, worked for me
Out of curiosity, why get rid of the gold? I thought it was one of the best for our trucks?
Suggest you use the search tool on the forum for more detailed and scientific answers. Its a prolific subject. At the end of the day , its your call. |
check the link in my sig for more info about the ford coolant
Have you tested your glow plug relay . The truck will act like that if it isn't working also .
Maybe I find it with search.... |
HAHAHA, do we own the same truck? Same problems here, got my ALT in the back seat, gonna install tomorrow.
