High pitched squeal at start up - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-17-2010, 05:53 AM Thread Starter
They call me Pete's Avatar
Is this the wastegate valve closing ?? Someone told me it is. If it is it's seems to be closing slowly now but hasn't in the past. I really need to learn my 04's motor better
They call me Pete is offline
post #2 of 6 Old 09-17-2010, 02:48 PM
There isn't a wastegate on your truck. Could be your belts making the noise.
2003 F350SD CCSB 6.0 2WD- cat delete/muffler delete/sinister EGR delete/CFM+ intake/CTS Insight /DieselSite Coolant bypass filter/GT3788 Powermax, Oilguard oil bypass filter,(new parts...oil cooler, 2 injectors, HPOP, ICP, IPR),
In the garage waiting to install - EGT probe
Family holiday enhancer: Zinger CF25BH 5th wheel
sixthgear is offline
post #3 of 6 Old 09-17-2010, 03:08 PM
How many miles since you changed your belt?
Newman is offline
post #4 of 6 Old 09-18-2010, 03:38 AM Thread Starter
OK so what I read searching is true about not having a wastegate. It's not the belt. It only last for 10 seconds and sound like something is closing. You hear the squeal then a thump like a flap closed. Maybe something to do with the heat/AC system
post #5 of 6 Old 09-18-2010, 09:33 AM
travisH3's Avatar
Quoted: 2 Post(s)
Feedback Score: 13 reviews
mine does this every start up. its something with the turbo or belt. because mine will real deep exhaust note, then a sqwak then the turbo spools up to idle. i hate that sqeak
T-rav
2010 F350 6.4-
s467 MPD single kit, H&S Jesse Byall tuning, No limit IC piping and intake,mishimoto intercooler, MPD billet CCV/oil filler, FASS with sump, SOTA A.W.O.L. polished wheels, toyo rt tires, RED Newton traction bars, oem projector retrofit and a bunch of LED lights LOL
Holderdown Performance #teamHDP
OUR FLEET: 2015 f450, 2014 Platinum F350, 2012 F450 6.7, 2010 F350 6.4, 2005 F350 6.0, 04 F450 6.0
travisH3 is offline
post #6 of 6 Old 04-14-2013, 04:43 PM
LoyalPatriot's Avatar
New here and I hope bumping a really old thread isn't frowned upon. I'm having a similar issue as the OP & I cannot find a cause or solution. When I start my 6.0 (2005 F-350 all stock), the truck will "lope idle" for a few seconds, then even out, then a loud quick squeal goes off followed by what sounds like a shot of exhaust leaving the tailpipe.
This is my 1st diesel truck and I'm still learning what all is going on but does anyone know what that sound is? It is not continuous, it does not make it while driving. Just a quick "chirp" or "squeal" like something closing or opening, then a big burst of exhaust leaves the tailpipe. Truck appears to drive fine w/ all power & average fuel mileage.
Any help would be so appreciated. Thanks.
LoyalPatriot is offline
