some light reading - Oasis interpretation, please? - Ford Powerstroke Diesel Forum
Old 06-02-2007, 07:58 AM
Just got this - Thanks Rodslinger!
Of course, "Run away or not?" is the first question. I think the answer is, it's not a perfect Oasis, but does not appear to be a lemon. (PLEASE speak up if you see it otherwise!)
Next question - what is a reaquired vehicle? (I'm thinking a trade-in? doesn't seen to have had enough problems before the "reaquired" to be a lemon.) And what is a "closed CUDL contact?".
What is a non-California vehicle with California emissions? I know CA is very restrictive with their emissions, why would anybody who did not live there put there emissions on a vehicle?
The other thing I noticed is there seems to be a lot of electical related work. Is there a chance that the there is something wrong in the electric system?
Any input on any of this is much appreciated!
Here goes: (this is part 1)
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 8 2H02 030008 3C3Z 6F089 AA D41 41 5496
AWS Claim Key: 5844281 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 20307 - * Name: RICH FORD SALES, INC. Ph: 505-2920000 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:03-MAY-2004 Doc #:10297801
Cust Comments: CUST STATES THAT THE VEH IS NOT GENERATING ANY BOOST, MORE SO WHEN TRAILER IS HOOKED UP. NOTE:CUST DOESNT WANT ANY
Tech Comments: STUCK VGT PERFORMANCE TEST 1 18,REPLACED VGT ACTUATOR,VGT65% 0PSI, REPLACED VGT65% 24PSI,TEST DROVE,CLEAR CODE 2263.
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 9 2H01 031202 3C3Z 6K775 AA D50 42 5744
AWS Claim Key: 6281619 Trx Code: S07 Labor Hrs: 1
Dlr Cd-Sub Cd: 20341 - * Name: ZIEMS FORD CORNERS, INC. Ph: 505-3251961 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:19-MAY-2004 Doc #:09362551
Cust Comments: CUSTOMER STATES LOUD AIR NOISE FROM FRONT OF VEHICLE, POSS HOSE FROM INNER COOLER BLEW OFF CHECK AND ADVISE
Tech Comments: VERIFIED CONCERN. FOUND INTERCOOLER SEPARATED AT PLASTIC. REMOVED INTERCOOLER & REPLACED. RETEST, 24 PSI BOOST.
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 12 2H02 030008 3C3Z 6F089 AA D13 41 9613
AWS Claim Key: 7408445 Trx Code: S07 Labor Hrs: 4.5
Dlr Cd-Sub Cd: 20307 - * Name: RICH FORD SALES, INC. Ph: 505-2920000 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2004 Doc #:11160601
Cust Comments: CUSTOMER STATES IDLES ROUGHT AT START,TURN OFF AND RESTART IT HELPS.HIGH ALTITUDE REALLY SUCKS VERY ROUGH IDLE,ROMPS
Tech Comments: STUCK EGR,VGT PERFORMANCE TEST 1 11,REPLACED PLUGGED EGR VALVE,EBP SENSOR REPLACED SOOT UP VGT,BOOST 22PSI,REPROGRAMED PCM,FICM,TCM
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 12 * * * * * * * 9613
AWS Claim Key: 7408444 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 20307 - * Name: RICH FORD SALES, INC. Ph: 505-2920000 St:NM Ctry Cd: USA Reg Cd: NA Repr Date:23-AUG-2004 Doc #:11160602
Cust Comments: RECALL 04S15
Tech Comments: RECALL PERFORMED 04S15 C
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 20 6Y20 000079 * RAV * A98 82 12302
AWS Claim Key: 10551452 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 11078 - * Name: SOUTH POINTE LINCOLN MERCURY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2005 Doc #:124014A
Cust Comments: COMPLETE REAQUIRED VEHICLE INSPECTION CHECKLIST
Tech Comments: REACQUIRED VEHICLE CHECKLIST COMPLETE
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 20 2G05 031405 * RECALEM * D41 42 12302
AWS Claim Key: 10551453 Trx Code: S07 Labor Hrs: 3.9
Dlr Cd-Sub Cd: 11078 - * Name: SOUTH POINTE LINCOLN MERCURY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2005 Doc #:124014B
Cust Comments: CHECK LOSS OF POWER UP HILLS AND RUNS ROUGH AT IDLE D41
Tech Comments: PERFORM DIESEL DIAG (SHEET ATTACHED) REPROGRAM PCMTO LATEST LEVEL
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 20 1A05 030008 3C3Z 9431 AB N12 42 12302
AWS Claim Key: 10551454 Trx Code: S07 Labor Hrs: 5.7
Dlr Cd-Sub Cd: 11078 - * Name: SOUTH POINTE LINCOLN MERCURY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2005 Doc #:124014C
Cust Comments: CHECK ENGINE NOISE UPPER HISSES N12
Tech Comments: REMOVE AFTER MARKET OIL FILTER SYSTEM PUT IN FACTORY OE REPLACED EXHAUST MANIFOLD
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 20 7N02 011109 1L2Z 14529 BA G07 28 12302
AWS Claim Key: 10551455 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 11078 - * Name: SOUTH POINTE LINCOLN MERCURY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2005 Doc #:124014D
Cust Comments: CHECK POWER WINDOWS INOP G07
Tech Comments: PINPOINT TST OPEN IN WINDOW SWITCH REPLACE MASTER WINDOW SWITCH
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 20 7M61 150201 XC3Z 18813 AA A02 39 12302
AWS Claim Key: 10604713 Trx Code: P86 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 11078 - * Name: SOUTH POINTE LINCOLN MERCURY Ph: *-* St:CO Ctry Cd: USA Reg Cd: NA Repr Date:21-APR-2005 Doc #:124014E
Cust Comments: REPLACE ANTENNA MISSING PER JENNY AT FORD RAV A02
Tech Comments: REPLACED MISSING ANTENNA PER JENNY AT RAV
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 24 2G04 031401 * 12A650 * D42 42 12425
AWS Claim Key: 11694222 Trx Code: S07 Labor Hrs: 1.1
Old 06-02-2007, 08:04 AM
a reaquired vehicle is a lemon, they reaquire it befroe the BBB gets involed....
the CUDL contract is something they open when they are having problems that are not getting solved with the truck..
Id stay clear of that one..
Old 06-02-2007, 08:32 AM
Part 2:
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2005 Doc #:08718701
Cust Comments: CUSTOMER STATES VEHICLE LACKS POWER ACCELERATING AND LIKE HARDLY GOES UNTIL YOU GET ABOUT 20 MPH
Tech Comments: 1 CHECK LACKS PWR HOOK UP WDS PID MONITOR ALL IN SPECC RESET KAM TEST DRIVE OK NOW
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 24 7P01 110501 4C7Z 13K359 AAA W05 42 12425
AWS Claim Key: 11694221 Trx Code: E83 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:12-AUG-2005 Doc #:08718702
Cust Comments: WIPER WORKS WITHOUT TURNING ON, HAVE TO GO TO HIGH SPEED AND THEN BACK DOWN, LIKE IT RUNS ON LOW SPEED
Tech Comments: 1 MULTI FUNCTION SWITCH NEVER DISPLAYS OFF RR SWITCH INTERNAL SHORT RETEST OK NOW
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 25 7D01 170101 F4TZ 13N021 B L26 42 11958
AWS Claim Key: 11921638 Trx Code: E83 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:03-SEP-2005 Doc #:08817501
Cust Comments: HEADLIGHTS ARE INOP AND RIGHT TURN SIGNAL BLINKS FAST
Tech Comments: 1 REPLACED TWO BULBS AND PLUG IN RF TURN SIGNAL
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 27 2G05 031405 * RECAL * D02 42 15355
AWS Claim Key: 12410347 Trx Code: E84 Labor Hrs: 1
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2005 Doc #:09094001
Cust Comments: CUSTOMER STATES VEHICLE DID NOT START YESTERDAY MORNING
Tech Comments: 1 TEST ELECTRONIC ENGINE CONTROLS NO CODES RE CALIBRATE PCM
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 27 6X04 010902 5C3Z 17682 EAA M05 33 15355
AWS Claim Key: 12410346 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:07-NOV-2005 Doc #:09094002
Cust Comments: CUSTOMER REPORTS PASS MIRROR IS FALLING APART
Tech Comments: 1 REPLACE RIGHT OUTER MIRROR AND COVER ASSY
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 28 2H01 030008 3C3Z 6K682 AARM P82 42 18141
AWS Claim Key: 12822843 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2005 Doc #:09305901
Cust Comments: CUST STATES THAT WHEN ON ACCELL FROM STOPS AND DRIVING AND ACCELL LIKE WHEN SHIFTING THERE IS A CLUNK WHINE NOISE
Tech Comments: 1 DIAG OISE FROM TURBO PID MONITOR AND ACTIVE COMMAND TURBO VARIABLE VEINS STUCK RR TURBO ASSY MTIME TO REMOVE STRIPPED REAR TURBO HOLD DOWN BOLT REASSEMBLE TEST DRIVE OK
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 28 1H03 030008 4C3Z 9F452 A D21 42 18141
AWS Claim Key: 12822842 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:26-DEC-2005 Doc #:09305902
Cust Comments: CUSTOMER STATES ENGINE IS STALLING
Tech Comments: 1 PERFORMANCE DIAG HOOK UP WDS CODE P0404 PPT REPLACE CARBON STUCK EGR VALVE AND REPROGRAM PCM TCM AND FICM CLEAR CODE
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 31 * * * * * * * 21088
AWS Claim Key: 14012484 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:09628302
Cust Comments: 59B01 RECALL
Tech Comments: ASSURANCE TEST DRIVE PER RECALL 59B01
AWS Claim Key: 14019557 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:09628303
Cust Comments: 06E17 RECALL
Tech Comments: PERFORM RECALLL 06E17
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 31 6H01 011103 3C3Z 7821537 AA G09 33 21088
AWS Claim Key: 14019558 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:09628304
Cust Comments: CUSTOMER STATES DRIVERS FRONT WINDOW RATTLES
Tech Comments: REPLACED WINDOW RUN
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 31 6N07 010801 1C7Z 8200 BAQ B69 33 21088
AWS Claim Key: 14019559 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:09628305
Cust Comments: CUSTO STATES THAT RIGHT FRONT GRILL WAS LOOSE AND FELL OUT
Tech Comments: REPLACED GRILL
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 31 5O01 110201 2C3Z 3504 AARM L68 42 21088
AWS Claim Key: 14019560 Trx Code: E84 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:17-MAR-2006 Doc #:09628306
Cust Comments: CUSTOMER STATES POWER STEERING IS LEAKING
Tech Comments: DIAGNOSE PWR STEERING LEAK REPLACED PWR STEERING GEAR BOX RETEST OKNOW
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 36 7M01 150101 * 18806 * A06 33 29358
AWS Claim Key: 14228422 Trx Code: E83 Labor Hrs: 6.6
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:10216501
Cust Comments: CUSTOMER REPORTS BOTH REAR SPEAKERS INOP
Tech Comments: 1 DIAG REAR SPEAKERS INOP NO WIRING FOR REAR SPEAKERS CALLED RADIO HOTLINE INSTRUCTED TO HARDWIRE SPEAKERS TO RADIO M TIME TO REMOVE SEATS INTERIOR TRIM REAR DOOR PANELS CARPETING AND RUN NEW WIRING TO ALL SPEAKERS AND REASSEMBLE WORKS FINE NOW
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 36 6X04 010905 F65Z 17B676 AB M05 42 29358
AWS Claim Key: 14217208 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:10216502
Cust Comments: M05 CUSTOMER REPORTS OUTSIDE POWER MIRRORS INOP
Tech Comments: 1 REPLACED POWER MIRROR SWITCH TEST OPERATION OK NOW
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 36 5G06 050301 F81Z 4A322 AA L88 D8 29358
AWS Claim Key: 14217207 Trx Code: E84 Labor Hrs: 2.8
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:10216503
Cust Comments: CUSTOMER STATES FRONT OR REAR AXLE LEAKS
Tech Comments: 1 REPLACED FRONT AXLE INNER SEALS
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 36 5J03 040302 2C7Z 18125 AA E42 33 29358
AWS Claim Key: 14217206 Trx Code: E84 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:10216504
Cust Comments: CUSTOMER REPORTS EXHAUST RATTLE NOISE
Tech Comments: 1 REPLACED REAR UPPER SHOCK BUSHINGS
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 36 2A01 031201 * 9N622 * G29 42 29358
AWS Claim Key: 14217205 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:10216505
Cust Comments: G29 CUSTOMER REPORTS WARNING INDICATOR LIGHTS AND CHIMES INOP
Tech Comments: 1 RECONFIGURE HEC FOR LOW FUEL LIGHT AND BELTMINDER AND HAS NO LOW COOLANT LIGHT
1FMSU41P73EC70930 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 27-MAR-2003 11-SEP-2003 156497 USA 36 1H03 030008 4C3Z 9F452 A D50 42 29358
AWS Claim Key: 14217204 Trx Code: S07 Labor Hrs: 3.8
Dlr Cd-Sub Cd: 01768 - * Name: KUNES' COUNTRY FORD L-M, INC. Ph: 262-7285544 St:WI Ctry Cd: USA Reg Cd: NA Repr Date:31-JUL-2006 Doc #:10216506
Cust Comments: CUSTOMER REPORTS ENGINE REVS AT IDLE AND MAKES INTERMIT KNOCK NOISE
Tech Comments: 1 PERFORMANCE DIAG HOOK UP IDS CODES P0299 P0401 VGT ACTUATIO TEST FOUND CARBON PLUGGED EGR VALVE REPLACED RELEARN TURBO
Old 06-02-2007, 08:33 AM
most definately stay clear!!
I was interrupted by life between my postings. Thanks for the help Marc!
Part 3:
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 EXCURSION BODY STYLE
XLT 4 DR WAGON 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
C1 ENGINE CALIBRATION
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 09-05-2006 DISTANCE 24325
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
09/11/2003
BUILD DATE
03/27/2003
SALE MILEAGE
00008
OUTSTANDING FIELD SERVICE ACTIONS
03E04
NON-CALIFORNIA CERTIFIED VEHICLES WITH CALIFORNIA VEHICLE EMISSION
CONTROL INFOR MATION
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
WARRANTY REPAIR HISTORY
07/31/2006
DEALER: Kunes' Country Ford L-M, Inc.
WARRANTY CLAIM NUMBER: 102165 ODOMETER: 029358M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
18806 CHASSIS RADIO 000 12651D 33 LOOSE PART
000 14200A
000 14200A1
000 18805B
000 MT18806
HOTLIN E INSTRUCTED TO HARDWIRE SPEAKERS TO RADIO M-TIME TO REMOVE
SEATS INTERIOR T RIM REAR DOOR PANELS CARPETING AND RUN NEW WIRING TO
ALL SPEAKERS AND REASSE MBLE WORKS FINE NOW
07/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
F65Z 17B676AB CONTROL ASY-O/S MIR 001 17676A 42 DOES NOT OPERATE PROPERLY
07/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
TA 30 001 3010E D8 FAILED GASKET/SEAL
XY 75W140QL 004 MT4A322
2C3Z 3254AA OIL SEAL-FRONT AXLE 002
F81Z 4A322AA SEAL FRT WHL HUB 002
F81Z 3254CB OIL SEAL-FRONT AXLE 002
07/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
2C7Z 18125AA ABSORBER KIT-REAR SH 002 18125AT 33 LOOSE PART
07/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
9N622 IND ASY ENG A/C REST 000 999A 42 DOES NOT OPERATE PROPERLY
COOLAN T LIGHT
07/31/2006
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 9F452A TRANSDCR-EGR BACK PR 001 6005F 42 DOES NOT OPERATE PROPERLY
000 6005F1
000 6005F1X1
000 6005F11
000 6005F12
000 6005F18
000 6005F19
000 6005F20
000 6005F25
000 12650D30
03/17/2006
WARRANTY CLAIM NUMBER: 096283 ODOMETER: 021088M
LABOR OP
CONDITION CODE
CONDITION DESC
000 59B01A
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
000 06E17B
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
3C3Z 7821537AA RUN-DOOR GLASS UPPER 001 23943ABT 33 LOOSE PART
000 MT21537
REPLACED WINDOW RUN
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
1C7Z 8200BAQ RADIATOR GRILLE 001 8200A 33 LOOSE PART
REPLACED GRILL
03/17/2006
LABOR OP
CONDITION CODE
CONDITION DESC
2C3Z 3504AARM GEAR ASY-STEERING 001 MT3504 42 DOES NOT OPERATE PROPERLY
1W1Z 19E889HB O RING - A/C COMP 001 3001A6
F7AZ 3F823AA 002
Old 06-02-2007, 08:38 AM
Wow, what a mess....
Old 06-02-2007, 08:46 AM
You think this one is bad, you should see the other one Rodslinger sent this morning!!! (At least I thought it was worse - leaks, and bellhousings, and this: "Cust Comments: C S TRUCK IS DUMPING FUEL INTO ENGINE AND SMOKING TERRIBLY. TRUCK TAKES AN EXTEND LENGTH OF TIME TO WARM UP IN AM.
Tech Comments: CHECK KOEO INJECTOR TEST PO278 KOEO ON DEMAND PO 278 KOER GLOW PLUG NO DTCS KOER ON DEMAND PO278 CMDTC PO 278 528 1378 401 562 2617 U1950 POWER BALANCE TEST SHOWS NUMBER OVER FUELING CHECK EGR MO REPLACE NUMBER 6 FUEL INJECTOR RETEST AND CLEAR DTCS REPLACE FAN STATOR CLEAR DTCS AND RETEST INNER FAN SHROUD IS MISSING AND FAN BLADE IS CRACKED OWNER DOE NOT WAN TO REP")
Guess the ones that are priced closer to kbb are that way for a reason...
Hey Marc, I don't know where on the central coast you are, but I spent many years in SLO trying to make my college career last as long as I could. Sure need to get back for a few days of R&R...
Old 06-02-2007, 09:05 AM
Dang, Farmgirl, you picked a real turd that time. Thank goodness for the Oasis reports and this website
Old 06-02-2007, 09:09 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
I wouldn't buy that truck with your Money for Marty to drive!!!!!
Old 06-02-2007, 09:29 AM
Farmgirl, how much you looking to spend?
Superior Ford in Siloam Springs Ark. has an 04 with 58K, asking 34K, and they will wheel and deal!
