Removed and cleaned my window seals in a effort to prevent the dreaded scratched glass. Worked real well if i say so myself.
Today: 1)new rear sway bar bushings (energy) 2)new thermostat 3)got my ficm repaired and installed 4)changed oil / added some ar9100 5)smoke switch 6)steering stabilizer 7)replaced the radiator drain plug that i broke good day for the old six leaker |
I'm not sure if the pre 05 clusters are the same but I just took out the 4 bolts that hold the cluster then rotated it up. All the bulbs are in 1/4 turn sockets. Pop them out and swap bulbs. Really simple.
Flushed the S%$t out of the coolant system trying to get my oil cooler to cool again
but it didn't work.
Slapped a new grille on mine. You can see the old one in my sig pic.
Realized today that mine puked for the first time from the festivities over the weekend...alcohol can be a b1tch
Can you get different color bulbs or is green it?
Well I don't know about 05-07 clusters, but in the 03-04 ones the bulbs are white, the green color comes through the cluster itsself...
I know that's no real help |
green is the color of the gauge cluster itself. If you want to change the color you have to change the face plate of it you can find them all over the net. Or I guess if you put a different color bulb it would have to mix with the green so you could go about it that way too i guess
