6.0 egr delete help - Ford Powerstroke Diesel Forum
Old 07-23-2010, 08:39 AM
Exclamation 6.0 egr delete help
I am currently in process of installing an egr delete kit. I have a feeling this is a pretty dumb question, but how do you get that orange hose off of the egr cooler? It has a little metal band holding in on there and I can't think of a way to cut it without damaging the piping inside.
Thanks!
Old 07-23-2010, 08:47 AM
I will try this in the meantime.
Old 07-23-2010, 08:48 AM
Lt. Negativity
You can cut it, just be careful and twist it off.
Old 07-23-2010, 08:59 AM
Isn't that just a press on fitting with an o-ring? Just try twisting it and pull it off.
Question for you. Are you replacing your oil cooler as well? If so, it will be much easier to remove that hose with the cooler on the bench. If you're not replacing your oil cooler is it because you know that your cooler is good?
Old 07-23-2010, 09:06 AM
After reading for a few minutes and rehydrating, yeah it appears that way. I'll give it another shot with some renewed vigor! Thanks
Old 07-23-2010, 09:08 AM
No, I'm just replacing my intake manifold with a abrannons modified intake w/ the egr deleted, and the modified up-pipe. I didn't have any problems with anything before doing this, just decided to do it before I did have issues. Thanks.
Old 07-23-2010, 09:14 AM
On my 03 the metal in the orange hose was corroded onto the fitting. I used a grinding wheel to cut it off (being very careful). You can also remove the port cover by removing the 2 torx screws that hold it to the oil cooler. That will also allow you to see the water outlet of the cooler so you can determine if it's corroded in there? (Sorry I had to replace my oil cooler twice so I always suspect they go bad easily.)
Old 07-23-2010, 09:25 AM
Just got it off by prying on it with a flat bar. Guess I failed to mention that when I cut that hose with a knife earlier, I cut it close to the egr cooler side, which gave me almost nothing to grab with my hand. So far nothing looks corroded, but i'm thinking about pulling off that cover you mentioned to see. Thanks Nylyon
Old 07-23-2010, 09:37 AM
Honestly, since you are in that deep (and that expense) put in the $200 oil cooler. Since you have an orange hose, you probably have the original oil cooler in there anyway.
