Power Steering Leak - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-22-2010, 07:32 PM Thread Starter
Power Steering Leak
Hello all i have an f-250 FX4 with a power steering leak, it seems to be somewhere under the master cylinder, i cant seem to find the leak though, i used some stop leak **** seemed to work for a month or so then started to leak again so im thinking maybe an o-ring or something.
does anyone know if there is a common place that these leak? Other than the leek it drives and steers fine, im just tired of buying tranny fluid.
2005 F-250 FX4 CC LB
Leveling kit
20" XD Revolvers 35" mt's
zoodad mod
JVC dvd touch screen
2 10" re sx subs in custom center console box
SCT with custom tunes and EGG probe
Muffler and cat delete
soon
arp studs
etc..
dstephens1962 is offline
post #2 of 7 Old 07-25-2010, 11:32 PM Thread Starter
So i have found out where my leak is it is the hose that connects to the master cylinder for the hydra boost. Gonna replace that this week. So do i just pop this hose off and replace it or is there a special way you know flushing draining etc.
and i also found this nut with a big washer and rubber absorber thing in the engine bay, i dont think it fell off anything but maybe it was left in there when the leveling kit was installed or something pics below. zippo for size ref.
Leveling kit
zoodad mod
soon
arp studs
etc..
post #3 of 7 Old 07-26-2010, 06:57 PM Thread Starter
anybody bump
Leveling kit
zoodad mod
soon
arp studs
etc..
post #4 of 7 Old 07-26-2010, 07:01 PM
looks like a shock nut/bushing to me.
19558077 is offline
post #5 of 7 Old 07-26-2010, 07:02 PM Thread Starter
that's what i thought but i checked my shocks and they were good, maybe left over from when the leveling kit was thrown on
Leveling kit
zoodad mod
soon
arp studs
etc..
post #6 of 7 Old 07-26-2010, 08:24 PM
Attachment 16490
Attachment 16491
Definitely looks like a shock bushing. Could have gotten dropped when installing the leveling kit. As long as both your front shocks have one on them I wouldnt worry about it.
As for replacing the hose you can just unscrew the hose, make sure you have a drain pan underneath to catch the fluid. Then install the new hose. You probably wont loose all the fluid since the hydroboost is up higher than the steering box. After the new hose is in just top up the power steering reservoir. Then start the truck and turn the steering lock to lock a few times and recheck the fluid. It will go down as the air in the system is purged out. Turning the steering lock to lock will help purge the air out.
Or if the fluid in your steering system smells burnt or is a dark color you could flush the system. I am not sure of the recommended way to flush the system though as I have never done it.
Also where is the line leaking from? Did you make sure the line isnt just loose? I would hate to see you buy a new line if the only problem is the line has come loose.
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
post #7 of 7 Old 10-08-2010, 11:11 PM
Power Steering
It's good that you already found the leak which connects to your master cylinder and hyrda boost. All you need know is to replace your rubber absorber or your shock absorber.
reinaldo is offline
