Recomended Order for Tightening Exhaust Clamps
Before I begin I did a search to no avail. I originally posted this in another section but I think this is probably the correct place for this question.
I have an 05 F-350 6.0. I just wrapped up some "basic" engine work replacing the STC fitting, cleaning the turbo, Tig welding a cracked bellows on the passenger side up-pipe and removing the EGR scoop on the up-pipe. This is my first time getting this deep into the engine but I am a mechanical engineer/machinist/fabricator so I have no problems working on machines. Everything is back together but now I have an exhaust leak coming from the clamp between the turbo inlet and exhaust branch. It doesn't matter how tight I make everything I can't get it to seal. So here is what I am planning on doing 1. Loosen all the exhaust clamps 2. Loosen the Turbo mounting bolts 3. Tighten the turbo inlet clamp 4. Tighten the two bolt clamp between the pas-side up-pipe and the branch 5. Tighten the EGR clamp 6. Tighten the driver-side manifold clamp 7. Tighten the pas-side manifold clamp 8. Tighten up the turbo mounting bolts I think in this order I will be able to get everything to seal and it won't be over-constrained. If there is an error in my logic or a best practice for this procedure can someone educate me? Thanks in advance. |
i have had luck with vibrating the clamps lighly with an air hammer when tightening with an impact. seems to work everytime for me
you have the riht idea tighten turbo to exhuast clamps first then turbo to pedestal
