I have a vibration in 4x4 on the front after I installed lift. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-20-2010, 11:18 AM Thread Starter
thundermaker's Avatar
Hi guys,
I installed a 6.5" lift on my 03 crew cab short box. Now, in four wheel drive it has a noticable vibration coming from the front end. The front drive shaft is at a pretty good angle- I beleive that is my problem. Does somebody make a front driveshaft with a cv joint? I don't see any options for cv drive shafts from aftermarket companies websites. Any opinions on how to fix this problem is greatly appreciated.
Aaron
325/65/18 Pirelli Scorpion ATR tires, 6.5" Procomp lift, straight piped 4" Silver Line exhaust, K&N filter assembly, RCD egr delete.
thundermaker is offline
post #2 of 12 Old 07-20-2010, 11:36 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Try shimming the front axle
You can find a few different angles as well Steel 2.5 Degree Shims by Blue Torch Fabworks and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH2
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 12 Old 07-20-2010, 12:06 PM
NotStock's Avatar
Thats odd that your having vib issues with only 6.5" of lift. Unless something is installed incorrectly or Pro Comp fudged on something you should not have any vibs until 10"+ of lift. Try to isolate where the vibration is coming from if possible. A custom driveshaft from a local shop would be a possible fix, aswell as pinon angle shims, or a transfer case clocking ring. But again, I think something else is going on here....
Precision Metal Fab
Trevor Hall
(520)465-7971
NotStock is offline
post #4 of 12 Old 07-21-2010, 07:26 AM Thread Starter
Thanks for the reply guys. I should mention that when I say vibration, its not that noticable, I get paraniod when it comes to my truck. I asked the wife what she thinks and she said she could hardly notice it, maybe I'm being to picky. NotStock, since you mentioned something might be wrong I called procomp. I talked to Jeff and he said check the slip yoke to see how far its pulled out and check the cv joint at the transfer case. I did a quick visual on that, the yokes look real close- I can't see any space between them but when it sits normal the shaft spins freely. Maybe under torque they are touching? When I had it aligned, he said it was damn near perfect, they didn't have to change the alignment shims. The truck is excellent w/ only 68,000 on her. Very seldom I use 4x4. The truck is in my signiture.
post #5 of 12 Old 07-21-2010, 07:44 AM
2006PSDSD's Avatar
Quoted: 24 Post(s)
Where are you feeling the vib, the steering wheel? Big tires are hard to balance at times, that could be all it is....
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #6 of 12 Old 07-21-2010, 02:52 PM Thread Starter
I feel it in the front end, maybe its just normal for it being a 6.5" lift. Its not bad, but I notice everything. When its in 2wd, even with 325's it drives perfect. I don't know, its probably nothing.. maybe its me.
post #7 of 12 Old 07-21-2010, 03:00 PM
BIGBLUE13's Avatar
I WOULD SAY CHECK ALL YOUR U JOINTS AND SEE IF THERE IS ANY PLAY IN THEM BECAUSE IF ONE ON YOUR FRONT DRIVE SHAFT CAN MAKE IT VIBRATE AT SLOWER SPEEDS IF THAT IS THE CASE I RAN INTO THAT WITH A COUPLE TRUCKS AT THE SHOP I WORK AT
GOT SCREWED ON AFTER 2 WEEKS OF HAVING THE TRUCK AND SWITCHING EVERYTHING OVER :
2002 ford f350 srw crew cab long bed 4x4
4 in magnaflow exhaust to 5 in tip
afe stage 1 intake
50% tint in front
30% in rear
many mods to come
BIGBLUE13 is offline
post #8 of 12 Old 07-21-2010, 06:16 PM Thread Starter
I'll check tomarrow, maybe the cv joint is getting alittle sloppy. Maybe because I don't use 4x4 that often and is garaged during the winter they are drying up. Thanks
post #9 of 12 Old 07-22-2010, 04:31 AM
Lt. Negativity
RescueF250's Avatar
Why would you want a CV joint, also something could have been installed wrong, I have 9.5 inch of lift and never extended my driveshaft its still the stock length and all might wanna relook at everything.
Matt at Gearhead,Doug at GoGo,Dave at Diesel Innovations,Ryan at Full Force Diesel,Eric at Innovative. Adam at First Coast
Built 2003 with 04.5-07 parts,Hey its a hybrid
Totaled
New Era Rescue 08 F250 CC/SB No limit stuff, H&S stuff, Fl pro stuff.
RescueF250 is offline
post #10 of 12 Old 07-22-2010, 07:32 AM Thread Starter
I had a brain fart when I first mentioned a cv joint, I forgot it already had one on the transfer case side. U-joints on the front feel good. But I did notice the front driveshaft does have alittle slop in the slip yoke- maybe a little more then a 1/16".
