EGR Disconnect
I am wondering if any knows if the EGR stays closed when you disconnect it, I have and 05 6.0L, i was thinking about buying a used one from the junkyard and plugging it in to eliminate DTC's,
![]() Thanks |
as long as you unplug it with the keys off yes it will stay closed , but boost will push it open some .
The boost pressure will push it open some. I just welded mine shut to make sure it would not push open.
You could put a small weld on the valve to keep it closed,
