possible egr trick - Ford Powerstroke Diesel Forum
Old 07-16-2010, 12:14 AM
Feedback Score: 4 reviews
possible egr trick
Could I take my egr valve out, leaving it plugged in. And put a old one that's closed back in the manifold. Without throwing any codes or lights?
Old 07-16-2010, 05:51 AM
Seems like it would work. We still have a giant scoop that obliterates half the up pipe tho
Old 07-16-2010, 06:02 AM
Slacker
You would likely get a soft code for insufficient EGR flow. It depends on the strategy, but most 05+ PCM's will set a soft code (meaning no Check Engine Light).
Old 07-16-2010, 06:22 AM
I wouldn't want a chuck of metal just laying around on top of the block though.... But yes, in theory it should work.
Old 07-16-2010, 02:21 PM
The egr that's plugged in could be zipped tied up out of the way. It wouldn't when a show in shine, but its better than dealing with a check engine light. And it will by me some time to get the full egr delete and custom tunes
Old 07-16-2010, 02:23 PM
Since the truck may throw a soft code, where is the sensor for the amount of flow? Ir is that part of the egr valve?
Old 07-17-2010, 08:21 AM
This is as close as I can get to finding the sensor. Not sure if the EGRVP is what does the work.
http://www.backglass.org/duncan/ps60...l/ps60_049.jpg
TheDieselStop.Com - Diesel Forum - TheDieselStop.com
http://dan.prxy.org/Truck/6L_bible_h.../Page_032.html
http://dan.prxy.org/Truck/6L_bible_h.../Page_055.html
It may end up being a group of readings. Not sure. Probably is the valve. Maybe a tech may come on and share the secret!
