how do i bleed my water seperator??? - Ford Powerstroke Diesel Forum
Old 07-14-2010, 12:18 PM
Red face how do i bleed my water seperator???
sorry guys im kind of a noob at this whole desel thing. my dads the proud new owner of a 2005 F250 and i need to find out how to release the water in the seperator...
any info will be awsome, thanks
viva la boost!
Old 07-14-2010, 07:40 PM
look on the inside of the frame rail near the drivers side door. you should see the separator there. It will either have a little valve you open to drain it or an allen head plug that you take out to drain it.
Old 07-14-2010, 08:09 PM
viva la boost!
You need to get one of these and replace the 6mm allen that is in there, just turn it in finger tight. The first time it will be a mess. When you change both filters you will have to turn on the key 3 times for 15 sec. each time to get the air out, the injectors on these 6.0 like fuel so never run one out of fuel or you will need 8 new one's and only use Ford filters. Here is the link.
Diesel Technician Society
So you are new to the 6.0 world you better watch this.
First thing you had better install one of these http://www.dieselsite.com/index.asp?...ROD&ProdID=324 to remove the casting sand before you have to replace your EGR cooler and oil cooler and if you do not have real deep pockets do not install a tuner or programmer the 6.0 is max out on HP now. PM if you need more info.
2 stroker
Old 07-14-2010, 08:24 PM
When i drain mine it never stops, i dont know what the deal is, i usually let it drain for a minute or two, it obvious it aint water coming out at that point all diesel.....
Old 07-14-2010, 11:23 PM
I have never had a problem but some have, they say to have a 1/2 a tank and have the nose down hill a little may or may not work.
2 stroker
Old 07-15-2010, 07:45 PM
i just drained mine a week ago and just let it dump till it was pure diesel i had diesel runin down my arm tho but hey who doesnt like the smell of diesel
