6.0L Questions - Ford Powerstroke Diesel Forum
Old 07-12-2010, 06:28 AM
6.0L Questions
Ok. So, my truck has been acting wierd. My truck has 4in exhaust, S&B intake, Banjo bolts, FICM tuning and SCT.
If I run "Xtreme Street" from Eric the truck pukes... not alot dribbles more the word for it, out of the degas bottle. Anytime I run the tune, it does this, even light driving.
If I run "SRL file" the truck occasionally does the same, but only on highway driving. It does it MAYBE once a month. Other that, its fine. wont puke. Has alot of pressure in the degas bottle after driving. Worries me because I smell coolant.
The level when its cold never changes. Im not loosing much/if any coolant. I made a line on the degas bottle and check it, and its at the same level when its cold.
I will be doing EGR delete/head studs/ and coolant filter kit this winter.
What do I need to check and fix this coolant problem now. Anybody have any ideas. Thanks in advance.
Pigg
Old 07-12-2010, 06:32 AM
Also, no oil in the coolant.
Old 07-12-2010, 06:44 AM
Send a message via AIM to wildfingas
What are your EOT's and ECT's at?
Old 07-12-2010, 06:52 AM
Lt. Negativity
When does it puke ? under a load ?
Old 07-12-2010, 07:26 AM
Not sure, dont have guages for that.
"Xtreme Street" pukes no matter what. Normal driving of WOT.
"SRL file" seems to puke at highway driving. not really under a major load. Wierd thing is, if Im hard on the truck it wont puke, untill next time I drive it, like a week later. Not sure if that helps
Old 07-12-2010, 07:34 AM
Ok Do you have access to an Insight or IDS? Check your ECT and EOT. I had a bad oil cooler that was causing coolant to flash and made it spit every once in a while like your describing. I was getting EOT 40 apart. oil cooler replaced and all has since been well.
Exactly as your describing on the highway normal driving it would spit a very little. My cruising temps were still about 30 degrees apart.
By the way. How can you even see the coolant bottle? you carry a step ladder around?
Old 07-12-2010, 07:37 AM
I suspect oil cooler as well. and I can tell when it pukes cause its on the frame and inner fender well... then I pop the hood and get a ladder!
Old 07-12-2010, 10:09 AM
I've heard of the caps on some resoviors being bad and i belive someone tole me they have an upgraded one? might want to check into that
Old 07-13-2010, 06:15 AM
So, is that what everyone would suspect being the oil cooler going bad? Anything else I can/should check out?
Hope it will make it to winter and I can do studs/delete and new oil cooler I guess.
Old 07-13-2010, 06:23 AM
Mine was doing the same thing, had to add coolant like every day! Mine was my head gaskets and oil cooler! So I had studs and replace cooler and no problems with either anymore. Not a cheap fix though, but with the money you got invested in the Pigg I would definatley get her done! PS i plan on getting some banjo bolts done too, what did you pay for the whole thing , bolts and labor? Just curious if you dont mind?
