Question!?!? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-11-2010, 06:28 PM Thread Starter
02fordpower's Avatar
Question!?!?
Is there anyway I can make my truck louder, I have a 2004 f250 6.0L...It purrs but I want it to make some noise running down there road , Im new to diesels so any help is appreciated! Thanks
2004 Ford F250 6.0L Turbo Diesel
All stock with some goodies to come!!
02fordpower is offline
post #2 of 10 Old 07-11-2010, 06:30 PM
back in the saddle
shu873's Avatar
4" straight piped exhaust, Cold air intake... The turbo will sing and the exhaust will rumble.
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 10 Old 07-11-2010, 06:36 PM Thread Starter
Ok, what will those set me back, and is there any certain brands I should look for? Also, what does a "cat" delete do, Im leaning towards doing the EGR delete bc I have only heard bad news coming if EGR cooler goes bad, head gaskets go etc., but what exactly is a cat delete and what is the purpose? Thanks
post #4 of 10 Old 07-11-2010, 07:17 PM
Larson24's Avatar
I've got a 5" MBRP no cat no muf and it roars from 2500 rpm on
2004
F250 Powerstroke 6.0 MBRP 5" turbo back exhaust, SCT tuned by Matt at Gearhead, Glowshift EGT, Boost and Fuel Pressure gauges, and the Zoodad mod
Larson24 is offline
post #5 of 10 Old 07-11-2010, 07:19 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
It eliminates some of the restriction of exhaust flow out of the motor, also will reduce your EGT's some.
A 4" straight pipe will delete the cat and muffler. I'm not into loud, so I just bought a "cat delete" pipe for the above reason.
I've heard that MRBP makes a decent system.:
MBRP Inc Performance Exhaust - Snowmobile, Diesel, Muscle Car, Exotic, Motorcycle and Sport Truck Exhaust Systems.
You might want to think about gauges also. ECT,EOT,Boost,Tranny,EGT, Fuel pressure.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 10 Old 07-11-2010, 07:31 PM Thread Starter
Im looking for the triple gauge pod: trans, boost, and pyro... Should I get a quad pod or just stick with those three? Thanks
post #7 of 10 Old 07-11-2010, 07:36 PM
Quoted: 4 Post(s)
Good choices, Have you given any thought to a "Scangauge II" or an Edge Insight? I have scangauge II and it gives me most gauges except EGT (pyro) fuel pressure, oil pressure.
Both will also scan for codes and clear them for you.
Scangauge II = $160 (or so)
Edge Insight=$250 and up + EGT probe $79
post #8 of 10 Old 07-12-2010, 05:48 AM Thread Starter
Larson24, if ya dont mind me asking, how much was your 5 incher?
post #9 of 10 Old 07-12-2010, 06:11 AM Thread Starter
Does anybody know where I can get a triple gauge pod, w/ mount and gauges and wires etc, for a decent price, or is it less expensive to buy it seperatley? I would like a tan one or a paintable one! Thanks
post #10 of 10 Old 07-12-2010, 06:51 AM
bfrank81's Avatar
I would also look at the Edge Insight or Insight CTS. I like that you can do this and keep the grab handle.
bfrank81 is offline
