oil filter? - Ford Powerstroke Diesel Forum
Old 07-10-2010, 04:20 PM
oil filter?
im going to be running amsoil in my truck but before i change the oil i was wondering what oil filter i should go with the amsoil one or the motorcraft
Old 07-10-2010, 04:28 PM
Illiana Chapter Director
I've always ran Motorcraft filters, so I can't compare the two. Name doesn't always = better though. I got in their website and just looked at a pic. Look identical to the Motorcraft and says it replaces Donaldson and Wix. Personally, I would stay with Motorcraft.
Old 07-10-2010, 04:42 PM
you need to be concerned with the recommended change interval. Also which aamsoil you are using and when you expect to replace the filter. The aamsoil states you can go 25k or one year. Whatever happens first. I would recommend analysis of the oil, at least at first. Aamsoil has the filter they recommend for that length of time?
Old 07-10-2010, 05:58 PM
i use Amsoil 5w-40 and change my oil every 10k miles and filter every 5k miles !!!
Old 07-10-2010, 06:04 PM
yeah i was gonna change it every 10k but what should i run for a filter
Old 07-10-2010, 06:05 PM
i use the amsoil filter...been using this combo for over 50k miles !!!
Old 07-10-2010, 06:26 PM
ok thanks for the info did you see any performance from the using amsoil this is going to be my first time using it
Old 07-11-2010, 05:47 AM
You won't see any performance hp/tq/mpg from ANY oil filter but the motorcraft is personally the way to go IMO.
