dealer cut my shroud in half.
took truck in for coolers again and i get it back with the fan shroud cut in half.
tech,tells me this is a normal operation? i told him, i have had this truck in four times for the same thing and never had my truck hacked up. he then says its in the service procedure. |
He obviously doesn't know what he's doing. The dealer would be buying me a new one.
thats not all, but this doesnt bother me as much.
he also had zip ties holding the top cac tube down to the alternator. they also left my degas bottle full of soot and said they could not get it cleaned out. i told them i wanted a new degas bottle and shroud and was told the degas wouldnt be a problem but the shroud was part of the job.so im trying to find out if that is true. |
He is just half assing his work and feeding you a line. Im going through the same stuff right now, I now have a competent tech fixing the other guys mistakes
he told me, you will thank me some day when the belt needs to be changed.
what truck do you have? when i did my rad (06 6.0l) the shroud comes out in one piece in about a minute.
sorry, its a 06 6.0 limited edition amarillo f350.
if thats the case its the same as mine and like i said it takes about a minute, two bolts on top and the two hoses and lift. i guess thats just too hard for them
