Egt probe question - Ford Powerstroke Diesel Forum
Old 07-07-2010, 11:00 AM
Egt probe question
Okay I'm getting ready to drill and tap my hole in the drivers manifold, my question is when I tap the hole how far or how
many turns should I tap it? Also what's the best way to drill it?
Old 07-07-2010, 11:06 AM
Unapologetically American
Feedback Score: 4 reviews
Tap the entire hole, if that makes sense. I used bearing grease on the tip of the bit and on the tap when I did it, 32,000 miles ago
Old 07-07-2010, 11:55 AM
Yea that makes sense.. It's only 1/4 inch inch thick so tap the whole 1/4 inch
Old 07-07-2010, 11:58 AM
You're just now getting an EGT gauge installed, after those mods in your sig
Old 07-07-2010, 07:10 PM
Thanks installed my probe, went easy... Also I know it's been asked alot but what temps should I see? Ect, eot, egt and trans? Thanks for the help
Old 07-08-2010, 04:09 AM
Glad it worked out ok For ya
Not sure of the temps, but you don't want to see your EOT and ECT delta spred more than 15* at operating temp, if so, you're looking at down happy time under the hood replacing/rebuilding the oil cooler, and /or the EGR cooler. What are you using to monitor those temps, Livewire?
The EGT's, don't hold it at more than 1300* for any period of time, only for short bursts (15-20 seconds). Trans, I haven't ever seen mine go over 195*, but I think that you can go to 210* without hurting it (don't quote me on that one though)
Old 07-08-2010, 05:15 AM
Okay thanks.. My trans temp got up to 172, ect was like 206 ad oil temp was 210.. Egt are like 700 crusin at 70.. I'm using the cts insight
Old 07-08-2010, 05:44 AM
Temps sound good to me! I just ordered my Insight, to replace my 3 gauge pod
