up pipe - Ford Powerstroke Diesel Forum
Old 07-06-2010, 09:26 AM
up pipe
i have a rcd egr delete i was going to put it on before my trip to CO, but we picked up some new accounts at work so i wont have time to do the full delete....my question is can i put just the up pipe on and unplug the egr valve? this way i wont have the hot gases entering the cooler?
thanks
Old 07-06-2010, 03:04 PM
thanks
Let's see. What if something like dust and dirt gets into the EGR cooler. Could it get all the way to the valve? Then How do you get it out when doing your delete?
Are you planning to have the intake manifold cleaned? I'm just thinking out loud here, I don't know.
Me myself? I wouldn't run like that.
Maybe pound in a freeze plug in the end of the cooler? Can that be done? From that angle? Don't know. I'm just processing this thought. And an interesting one at that!
Have a great trip!
Different question. Have you checked your ECT/EOT temp differences? How are they running? Why I ask is you might want to look into changing your oil cooler at the same time as your egr delete.
Old 07-06-2010, 04:56 PM
I really wouldn't suggest it without a block off for the egr cooler.
Old 07-06-2010, 05:46 PM
Ok thanks for the info. I too was wondering about the dirt getting in the system. My EOT and ECT are 5-6 deg. From each other. But when I have it all apart I'm going to do studs too so I'm going to replace the cooler and do all the upgrades I can. I installed a diesel site coolant filter over the weekend so should keep my oil cooling from getting to bad.
