exhaust leak - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-05-2010, 09:47 PM Thread Starter
dusthol's Avatar
exhaust leak
i'm having a loud hissing noise coming from under the truck, also a very high pitched whistle when accelerating. i cant find where its coming from, ive pinpointed it to be from the back of the motor, possibly the crossover pipe. is it common to have a break in that pipe?
dusthol
dusthol is offline
post #2 of 8 Old 07-06-2010, 06:48 AM
yes, but usually you loose boost pressure.
ASE Master Certified Technician
04 Powerstroke lovin it
thenubsterman is offline
post #3 of 8 Old 07-06-2010, 09:03 AM
I have air noise on the 06, Im sure its because the cat is clogged with 125k miles.
I hear it at 10 to 20 boost. Below 10 I do not hear it.
Im going to hollow the cat next week.
When the cat clogged on the 04 at about 100k miles, I was pulling a trailer and power would come and go with a steady accelerator.
JoeH is offline
post #4 of 8 Old 07-06-2010, 11:28 AM
Poss. EGR cooler clamp loose?? Had that a few days ago it sounded like a very crappy sax player. Mine wound up being a loose bolt on the Y pipe flange between the up pipe and the Y on the pass side. Hope that gives you something more to look for.
emhowland is offline
post #5 of 8 Old 07-06-2010, 11:30 AM
My 6OH Hates Me
mudrunninpig's Avatar
Quoted: 24 Post(s)
Check you turbo up pipes to see if they are cracked in the flex section.
Mike
"The Iron Pig"
mudrunninpig is offline
post #6 of 8 Old 07-06-2010, 04:12 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
Dang it! Here I was just at a firework stand this weekend and I didn't buy a couple packages of smoke bombs! I'd clean my shop vac out and light one of them suckers and put the hose on the exhaust side of the shop vac and blow the smoke up my exhaust pipe to find any leak I might have after I've done some wrenching in that area.
Now, I'm using a stick with a piece of ribbon on it to find the leak while the truck is running.
Maybe there is still a stand in town.
Edit: There was a stand selling out. Got my smoke bombs for future work.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #7 of 8 Old 07-08-2010, 07:17 AM
BruteNasty's Avatar
I just found out last night that my down pipe and up pipe are rubbing, and caused a hole in the uppipe
2003 F350
SCT w/ Innovative tunes
Banks IC
High Ram intake
afe filter
zoodad
6an fuel fittings in head
regulated return
Airdog 2
elite turbo
egr delete
coolant filtration, elc
ProComp 6"
WELD Evo 20's
37" mudgrapplers
BruteNasty is offline
post #8 of 8 Old 07-08-2010, 07:42 PM Thread Starter
dusthol's Avatar
i am still trying to track it down, i will keep u guys updated. its been hectic trying to move, and looking at a hot motor when its 105 degrees outside. by the way i had the egr cooler deleted a few months ago, looks like a silver plug w a clamp around it on the exhaust.
dusthol
dusthol is offline
