Brights Won't Work
I have a problem with my brights i did the fog light brights mod and thats when this happend, i did this mod and my brights won't come on it just goes black
even my little light that come on when the brights are on in the cluster deosn't come on. i have changed the bulbs and even looked at the old ones and the elements are still good. but i also switched it back the way it was without the mod and is doing the same thing. ![]() any help would be great thanks -pat-
Wiring is screwed up somewhere
somewhere in the wiring is messed up. the brights dont run with the low beams at the same time.
also change the fuse or check it. |
i aint trying to get the highs and the lows to work at same time, its the FOG LIGHTS and the highs i did the mod on and its only one wire and its for the ground on the fogs so in theory it shouldn't mess with the brights but i will check the fuse but the fuse runs the low and highs so i don't think that will be it but you never know. any other ideas would be great
what i was tryin to say was the lows and highs are sparate in wiring.
so are you tryin to get the fogs to turn on with the brights? |
