Summer oil change - Ford Powerstroke Diesel Forum
Old 07-03-2010, 03:03 PM
Summer oil change
Hey guys it's time for my summer oil change and was wondering whats best for summer. Right now I'm running 5w40 extreme blue. Is that a good oil to stick with or should I try something different. Thanks
Old 07-04-2010, 03:54 AM
i would stick with that. however, if you wanted to change you could switch to the t5 rotella 10w30, there is an oil analysis around here somewhere and it show good results.
Old 07-04-2010, 07:09 AM
Shell Rotell T5 10w30. At walmart. Enough said
Old 07-04-2010, 07:20 AM
It's all motorcraft for me
Old 07-04-2010, 09:14 AM
I will be using motocraft filter forsure just tring to figure which oil to use
Old 07-04-2010, 09:36 AM
i use Amsoil 5w-40 all year long !!!
Old 07-04-2010, 09:39 AM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
rotella 15w 40
Old 07-04-2010, 10:30 AM
i read good things about amsoil to
If you like it use it the 40 is good for summer and the 5 is good for winter you are covered on both ends. I'm running Amsoil 15w40 here in Oregon it does not get that cold to use a 5w.
2 stroker
Old 07-04-2010, 11:09 AM
thanks for the info man
