Is the VGT-SS good? - Ford Powerstroke Diesel Forum
Old 07-02-2010, 04:18 PM
Is the VGT-SS good?
S300 Turbo Swap... - Competition Diesel.Com - Bringing The BEST Together
These guys sure dont think so.
What do you guys think?
Old 07-03-2010, 01:48 AM
Have you looked at the new Garrett Powermax Turbo?
Old 07-03-2010, 10:09 AM
Yes and that is a very good turbo. I want to go with a non VGT. BUT... Part of emissions testing has to do with a smoke test. From idle they snap the RPM's to 2.5k-3k. They look for smoke but how much for how long is EXTREEMLY debatable...
So I am trying to do as much research on turbos as I can before I get one. The SS is the biggest that I might get and the garrett powermax is the biggest I will get. I know it I got bigger I WILL smoke too much. So far I am fixed on either 155cc or 175c inj.
But this is about the VGT-SS. So what are your opinions on this??
Thanks
Old 07-03-2010, 12:19 PM
I wanna go fast!!!
I had a VGT SS and it blew up within a year and a half.
Old 07-03-2010, 01:26 PM
And there ya have it.
Old 07-03-2010, 01:29 PM
'Merica
i 2nd that.
Old 07-03-2010, 03:46 PM
That is what I am worried about. when did you get it and what were you using with it?
What broke?
Did you have a blow off valve?
Old 07-03-2010, 06:08 PM
I wanna go fast!!!
What broke?
I got it about two and a half years ago and last summer the bearings went out and the exhaust side turbine shredded to sh!t.. All the veins and the housing is full of little dents from the veins coming apart.. I didnt have a blow off valve, also that was with stock injectors.
Old 07-03-2010, 06:57 PM
Wow, with stock inj? I hope that was poor quality control... With stock inj I am sure you would not require a blow of valve because the stock inj could not push enough fuel do breake that turbo... Unless I am wrong... ???
So what happend after it broke?
Old 07-04-2010, 06:48 AM
here is my opinion on the VGT SS
VGT SS price- $2300 + $700 core
Garrett Powermax- price $1200 +
VGT SS specs- Inducer 64.7mm/Exducer 88mm
Garrett Powermax specs- Inducer 63.7mm/ Exducer 88mm
VGT SS- rebuilt charger
Garrett Powermax- New from the OEM manufacture
