244000 miles hold up to tuner - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-30-2010, 07:29 AM Thread Starter
killa071's Avatar
My truck is an 03 6.0 auto crew cab short box with 244000 miles on it been bone stock all it's life minus a str8 and egr delete would this truck survive a sct livwire I don't wanna beat the piss outa it just to get mileage and a lil performance and I was thinking of getting some new injectors any suggestions on where to get some for a good price thanks in advance guys
2011 F350
mobile 1 5-40
killa071 is offline
post #2 of 6 Old 06-30-2010, 07:44 AM
LHMissions's Avatar
Whats a str8?
I have an '03 6.0 in my sig. Everything done in the sig at 199,000 miles minus the Banks at 179,000.
Any tuner you add - regardless of manufacturer, custom tune, canned tune - all are going to increase cylinder pressures. With your truck with original head bolts and original head gaskets - (assuming original since you didnt mention not being) - your factory head bolts and head gaskets are probably on their way out anyhow - typically stock doesnt last beyond 100,000 miles let alone (as both our trucks have lasted 200,000+) .
As far as mileage - its really hard to get good mileage with a tuned truck. Some reason when you tune your truck - your right foot gains about 4 pounds . Really bazaar.
Just as an example - not pushing any tuner here - with my Banks - I picked up 4-6mpgh under normal driving - towing I picked up 2-5mpg depending on terrain.
Not trying to be a kill-joy here but just sayin' --> You may want to lay aside in your budget around $3000 for studs and gaskets. (not including cost to magnaflux, hot tank, and deck heads if necessary) Increased pressures will totally kill your head bolts (they stretch) and gaskets will fail. Even without a tuner - eventually your bolts will fail and you will still need studs and gaskets. Just a matter of time.
'03 6.0 F250 FX4 Supercab Longbed 4wd <>< - SOLD
225,518miles!
Diamond-Eye 4" Off-road turbo-back
Full DIY ERG delete, Zoodad Mod, 5R110
ARP studs!!! and Decked Heads, Autometer EGR & Glowshift EOT, ECT, Boost
18x9 Black DC-2 and LT295/70R18E Nitto Terra Grapplers
LHMissions is offline
post #3 of 6 Old 06-30-2010, 08:00 AM
bfrank81's Avatar
So true! It doesn't matter if you have a car, truck, bike, boat that always seems to happen.
bfrank81 is offline
post #4 of 6 Old 06-30-2010, 09:39 AM Thread Starter
killa071's Avatar
Head gaskets were replaced at 180000 miles new head bolts donno if he put studs or factory bolts but he said they were changed out and everything else was good heads were checked and they were still good not warped or anything egr was deleted so I donno my buddy has a king ranch and a tuner on it he always run high hp tunes and he is hard on it and it had headgaskets changed prior to the tuner and he has Had no issues with it and he still has egr on his truck His truck only has 100000 though o ya and str8 means straight pipe exhaust
2011 F350
mobile 1 5-40
killa071 is offline
post #5 of 6 Old 06-30-2010, 02:06 PM Thread Starter
killa071's Avatar
Bump any one with info
2011 F350
mobile 1 5-40
killa071 is offline
post #6 of 6 Old 06-30-2010, 04:59 PM
if you do not want to find the week spots sooner than later stay stock.
like stated above the tuners no matter what you choose, will add stress showing the week spots.
blood is offline
