Truck broken into need help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-28-2010, 11:59 PM Thread Starter
LSU Tigers's Avatar
So last week my truck was broken into, first they took alot but it can be replaced. So i need help on changing my door handle out, what they did looks like they took a hammer and screw driver and knocked in my key lock part of the handle, and the door will no longer lock. So 2 questions can i change the whole handle out and put one with out the key lock on it (so this cant happen again) like the drivers back door or do i need to put one with lock back on? please help
06 F-250 CC
4" turbo back
Zoodad
Airaid intake
SCT Livewire ID custum tunes
LSU Tigers is offline
post #2 of 7 Old 06-29-2010, 08:48 AM
Davey~do's Avatar
Yes, you can purchase the rear door handles and install them in the front doors to replace the ones in front, as long as you have keyless entry. Here's a link for reference. I have a friend living in Houston who did it to his '06.
Just be advised, however, that if someone breaks into it again by the same method (the plastic part that is not actually the handle can be broken with enough force) that it will most probably do quite a bit more damage than was done by punching the lock. Stands to reason since they are going to have to beat on it quite a bit harder. Either that or he will just shatter the window to gain entry.
David
2016 CCSB SRW FX4
Davey~do is offline
post #3 of 7 Old 06-29-2010, 11:05 AM
xjeeper's Avatar
There is a metal dodad that you can get that prevents that method of break in, I got a set at a tool box place in PHX. I cannot remember the manufacterer, but they were not expensive. They install inside the doors after you remove the door panels, install was easy, no drilling etc.
xjeeper is offline
post #4 of 7 Old 06-29-2010, 11:21 AM
KING of BLING!
ExtremeFord4x4's Avatar
Jimmi Jammer Passive Truck, Car and SUV Security
2005 Ford Excursion 4x4 Limited(Current)
2006 F350 Crew Cab 6.0 Lifted 6",22's,SRL, Edge CTS(Totaled)
2003 F250 Crew Cab 6.0 Sonic Blue Sport 38s/20s(SOLD)
2001 F250 Crew Cab 7.3 w/ 08 Clip 37s/22x14s(SOLD)
2005 Excursion Limited 6.0 I.D. Tunes 38s/20s(SOLD)
2008 F350 Crew Cab 6.4 Job II 2.5" Leveling kit(SOLD)
2001 F250 Single Cab Short Bed Looney Tuned 6.0 Conversion Studded/EGR Delete(SOLD)
ExtremeFord4x4 is offline
post #5 of 7 Old 06-29-2010, 12:12 PM
Lubbockguy1979's Avatar
Quoted: 8 Post(s)
Send a message via Yahoo to Lubbockguy1979
Jimmy jammers will help but it all depends on how bad they want in. Best bet is not to leave valuables in the truck ans if you do put them out of sight. If you lady friends are with you make sure they don't hide their purse at the place you park. I had a buddy get his window broken and all they took was the purse. Evidently they saw her put the purse under the rear seat. They busted that window and took it.
Randy
2006 f250 4x4
crewcab shortbed
lariat auto
Some tuning, gauges and other assorted non factory dodads
Lubbockguy1979 is offline
post #6 of 7 Old 06-29-2010, 02:48 PM Thread Starter
LSU Tigers's Avatar
Thanks to all for the replys
06 F-250 CC
4" turbo back
Zoodad
Airaid intake
post #7 of 7 Old 06-29-2010, 05:26 PM
6.0DSLPWR's Avatar
Sorry about your truck. Same thing happened to mine a few months ago. They punched the drivers door lock and started punching the ignition out before they left empty handed for some reason
Luckily my lock was undamaged but I did need to buy a new handle since they broke mine. Cost me $150 for the handle. I was also going to buy those jimmy jammers but I heard that somebody had them installed on their truck and it still got broken into by popping the lock in the handle so I figured they werent a 100% guarantee and werent worth buying. If they want in they will get in.
-Aaron
2005 Ford F350
SCT X3
Isspro Performax Gauges
Dieselsite Boots
Fumoto Oil Drain
Coolant Filter
MBRP Dual 4" Straight Pipe
Harley Headlights
Pioneer In Dash GPS
6000K HID Headlight and Foglights
Smoked Lights
6.0DSLPWR is offline
