Tranny Pan Capacity - Ford Powerstroke Diesel Forum
Old 06-24-2010, 01:37 PM
Tranny Pan Capacity
Does 5 qts sound about right ?? Dealership said about 4 but when I drained it sure as hell looks like more. I put 5 in and drove then checked but it still looked low. Hard to read dipstick. Atleast I finally fixed the temp sensor
Old 06-24-2010, 02:24 PM
Here is a thread about your tranny. Scroll down for fluid change info. It's a good read. Lots of info.
I drained nearly 8 quarts out of mine.
TorqShift Transmission - Information and Troubleshooting - Ford Truck Enthusiasts Forums
Old 06-24-2010, 04:54 PM
I put 8 qts back in mine after draining.
Old 06-26-2010, 07:13 AM
Thanks for the link. Pisses me off that the stealership parts guy couldn't tell/find out how much it would take. "Oh yeah 4 qts. will be enough" WTF!!!
Old 06-26-2010, 07:41 AM
When I did mine the first time, I had read somewhere about using old milk jugs and making quart marks on each one, then drain the fluid into each one. Then I knew. Was time consuming, but it was a good learning tool.
Old 06-26-2010, 01:51 PM
IIRC the owner's manual states 7+ quarts...
Old 06-27-2010, 01:46 AM
Well if I was really smart I would have drain the fluid into a CLEAN container and reused it . The fluid was very clean. I figured it wouldn't have been that clean. The place where I bought it from must have changed the fluid. I've only put 22k on it since I've owned it. Live and learn
Old 06-27-2010, 05:47 AM
Not really a bad thing to do when buying used. Now you know for sure the right fluid is in there. And, you know how many miles are on the fluid. I changed mine out the week I bought mine. Didn't matter what the fluid looked like.
Piece of mind.
