Poss. to replace one piston w/ engine in? - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-23-2010, 08:28 AM Thread Starter
'05 f350, #6 piston scorched from bad injector. Is it poss. to replace the piston by pulling the oil pan off? Do you have to break the bottom section of the block to get to the rod cap? Cab is off so I can lift or even remove the engine if needed.
DCM554 is offline
post #2 of 18 Old 06-23-2010, 09:22 AM
Lt. Negativity
RescueF250's Avatar
Nope gotta pull the engine. You wont have enough room having it in the truck. Also if its scored you really gonna just put another piston and rings back in, you better hone it some and get the surface fixed or your rings are gonna get destroyed again. Also if your gonna go that far your better off replacing all the rings, and checking your block.
Matt at Gearhead,Doug at GoGo,Dave at Diesel Innovations,Ryan at Full Force Diesel,Eric at Innovative. Adam at First Coast
Built 2003 with 04.5-07 parts,Hey its a hybrid
Totaled
New Era Rescue 08 F250 CC/SB No limit stuff, H&S stuff, Fl pro stuff.
RescueF250 is offline
post #3 of 18 Old 06-23-2010, 02:23 PM Thread Starter
rod caps
Can you get to the rod caps with the pan off?
DCM554 is offline
post #4 of 18 Old 06-23-2010, 02:25 PM
Lt. Negativity
RescueF250's Avatar
You wont be able to remove the pan unless you drop the trans and raise the motor up, taking the motor mounts off etc. Either way your gonna have to pull it in the end.
Totaled
post #5 of 18 Old 06-23-2010, 02:38 PM Thread Starter
rods
With the motor out can you pull the pan and get to the rod caps without taking the crank out or splitting the lower part of the block?
DCM554 is offline
post #6 of 18 Old 06-23-2010, 02:51 PM
Lt. Negativity
RescueF250's Avatar
You might be able to have enough access heres a picture of mine torn apart.
Totaled
post #7 of 18 Old 06-23-2010, 05:40 PM
DevilDocTater's Avatar
I can be done with the engine in, but you would have to pull the cab. Long story short the dealer dropped a screw down my intake and caused the valves in #3 to slap the piston. RCD had the cab off for studs and HGs and was able to jack motor up, pull pan and replace piston. But i didnt have any cylinder issues. Rescue is right about the honing issue.
2004 F-350 6.0 6" suspension lift sitting on 35's 6spd MANUAL 4" Turbo Back Exhaust, AFE Air Box, (ARP Studs, New HG's and Complete EGR Delete by Josh at River City Diesel) Coolant Filter from Dfuser, Stainless Steel Up-Pipe from RCD, 4 gauge pillar with Autometer Phantom Series 1 gauges. Boost, Pyro, Fuel Pressure and Oil Temp. Shimmed FPR. Improved Banjo Bolts, Fabtechs all around with Procomp Steering stabilizer all from RCD
DevilDocTater is offline
post #8 of 18 Old 06-24-2010, 01:53 AM Thread Starter
piston
Thanks Rescue for the pic. Does not look too bad. Dealer pulled the cab and found the piston and I had them stop to either junk the truck or find a cheaper solution. Could not dump $13k in a new motor.
Head is off. I think I'll lift out the eng/tranny unit, roll it over and pull the pan and piston. Can the block be resleeved without total diassembly if the cylinder is scored too bad? And don't worry, it will be honed well if we can use the cylinder.
DCM554 is offline
post #9 of 18 Old 06-24-2010, 04:14 PM Thread Starter
Add burned exh valve
Pulled the head off to look at the piston and it is fried. Checked out he head and one of the exh valve is partially eaten up. Seat looked ok but I will ck further. Anybody got 2 used intake and 2 exh valves laying around? I still might try to patch this thing up. I hate to get beaten by this thing.
DCM554 is offline
post #10 of 18 Old 10-05-2012, 08:19 AM
MoserJR82's Avatar
Yes, you can replace a piston from below without pulling the cab or the tranny. I literally just did this last week.
Take all 8 motor mount bolts off the cross member, lift your engine a couple inches with a cherry picker, then pull your lower oil pan, up take tube and upper oil pan. You can then access your connecting rod bearings and push your bad piston out through the top of the head. It's really not that bad of a process, just be careful not to lift the engine TOO much.
This is obviously a late reply but may be of use to someone in the future.
2005 F-350 KR, CC, SB 6.0L
Sinister EGR Delete
Final Charge Coolant
Rotella T6 5w40
Sinister Coolant Filter
MBRP 4" turbo back straight pipe
Blue Spring Upgrade
Droid Torque App
SCT X3 Spartan Hyrbid Race Tune
ARP Head Studs
Aftermarket degass cap
Cowl hood (not functional)
Atlas 80 PHP FICM tune
Rebuilt FICM thanks to FICMRepair.com!
Rancho RS9000X front shocks
MoserJR82 is offline
