Normal Readings for Oil Temp, Coolant Temp, etc. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-23-2010, 05:37 AM Thread Starter
Pathfinder22's Avatar
Quoted: 2 Post(s)
Garage
I'm sure a thread is out there with this info, and I'd appreciate if someone can point me to it. Looking for what acceptable range or normal readings are for (truck is all stock and I have no gauges):
Oil Temp
Coolant Temp
Fuel PSI
and any other key indicators I should be looking at.
'06 F350 Lariat CC DRW 6.0L PSD
fully Bullet-Proof'd incl Sinister Diesel Coolant Filtration System, Train Horn, Killer Audio w/ back-up cam & 10" sub and Re-upholstered seats w/ custom canvas covers...240k plus and running strong!!
Pathfinder22 is offline
post #2 of 3 Old 06-23-2010, 06:58 AM
rpm_carriers's Avatar
This is taken from a previous post...
STOCK READINGS:
............................Normal...........Sever e Service........Alarm
Tranny Temp........150 - 195.............195 - 200.............220
Coolant Temp.......190 - 195..............195 - 210............215
Fuel Press..............60 - 50.................50 - 45..............45
EGT - pre Turbo......650 - 1200.........1200 - 1250.........1300
EGT - post Turbo.......700.....................900........... ....1000
Boost.....................0 - 26.................27 - 28...............28
Oil Temp................200 - 220............220 - 235............235
I highly recommend that you purchase something like the Edge Evolution. Mounts nicely to the corner of the dash. You can monitor all of the above values with the Edge except for Fuel Press. To do this you would have to purchase a manual gauge tapped at the fuel regulator.
Also another essential item (IMHO) for even a completely stock truck is a coolant filtration system. I purchassed mine from DieseSite. I've cut open the Baldwin filters and you would not believe the sand and particles flowing through the cooling system.
2006 F250 XLT Lariat 4x4
2004 F450 XL 262,000 miles
rpm_carriers is offline
post #3 of 3 Old 06-23-2010, 07:21 AM
if you like your truck get some type of way to monitor its performance no matter what you drive ....GET GUAGES .... or be like me and learn the hard way ....
scott52575 is offline
