6.0 Water Pump GPM / How to Test and Replace - Ford Powerstroke Diesel Forum
post #1 of 3 Old 06-22-2010, 01:58 PM Thread Starter
rpm_carriers's Avatar
I recently made a post about VC-9 and how well it cleaned the entire system. The nearly new Oil Cooler is working much better after flushing 9 times before the water was clear. One problem that didn't go away is the ECT has a sort of wave effect ( 198, 199, 200, 201, 202 etc on up to 215) or more and come back down own its own. Sometimes hitting the 220 mark causing the fan to run. This condition occurs under constant load (15lbs boost), steady speed (65 mph), roughly 2400 rpm (4.88 Dana S110). I must also note that the truck is slightly modified. No Cat, No Muffler, Welded up EGR Cooler. Also my empty weight truck and trailer is 18,900 lbs. The load I took to Winnie, TX this morning weighed roughly 11,000 lbs. GVCW 29,900lbs.
When I returned home, I measured the water flow for 5 minutes using a spare 3/8" hose hooked to the EGR return to reservoir tank.
Work Truck - 5:00 min - 2.0 quarts coolant / Personal Truck - 5:00min - 3.5 quarts coolant.
I'm sure I'm answering my own question, but it looks like I need a water pump.
Does anyone know the proper way to test the water pump? I've looked for a tutorial or how to change the pump on powerstroke.org and cant find anything. Maybe someone has a link or some first hand knowledge and willing to share. Or do you just dive in the fan clutch with a 2X4 a pipe wrench and cheater bar?
http://i751.photobucket.com/albums/x.../Photo0114.jpg
http://i751.photobucket.com/albums/x.../Photo0115.jpg
2006 F250 XLT Lariat 4x4
2004 F450 XL 262,000 miles
rpm_carriers is offline
post #2 of 3 Old 06-23-2010, 05:27 AM Thread Starter
Come on Guys, I know someone out there is an expert on the 6.0 cooling system...
post #3 of 3 Old 06-24-2010, 03:30 AM
Quoted: 11 Post(s)
I doubt that anyone has flow information from a port. When questioned the mechanics so far have said that the only test is to remove it and check the impeller.
But the EGR return may not be the best place to check the water pump as I would expect it's flow to be dependent on the condition of the cooler. The heater supply line may be a better indicator of the water pumps output.
Jack
Former Vehicle Test Manager, Friction Products.
03 F350SC 4x4 6.0 Auto 5/30/03
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
TooManyToys is online now
