PSA: Rebates on Shell Rotella - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-20-2010, 07:53 PM Thread Starter
$20 on 3 gallons of T6, $10 on 3 gallons of T5, through July 9:
Link:
http://www-static.shell.com/static/r...10_diy_mir.pdf
ClarkSJ is offline
post #2 of 4 Old 06-20-2010, 08:15 PM
back in the saddle
shu873's Avatar
I'll bite... I run the rotella full syn. With a $20 rebate on 3 jugs that's basically buy 2 get 1 free. $19.50 a gal at walmart here too. Thanks for the post!
Kurt
'06 True Blue/Silver 250 crew cab
ARP's, EGR blocked
AFE stg.2, MBRP 4" pipe
Air Dog 150, ITP reg. return
Bulletproof oil bypass system
Banks technicooler
Ride rite air springs in the rear
EGT, boost, and fuel pressure gauges by DiProcol on the pillar
Plus a few other odds and ends...
shu873 is offline
post #3 of 4 Old 06-20-2010, 08:28 PM
thanks needed to change the oil in the truck and to get a good deal might on synthetic might as well do it
Jason, But you can call me Sir!!!
2001 F-350 CC Dually~Built and tuned by PHP~572/1161ft lbs fuel only~few LEDs here and there
GOPOWERHUNGRY.COM
Lowdown89 is offline
post #4 of 4 Old 06-20-2010, 08:31 PM
RRF985's Avatar
I picked up some T6 a couple weeks ago when I saw this rebate. Definitely well worth it.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
