changing oil in diff, what to use ?
i have changed oil in both front and rear 4 months ago, but its leaking from front so need to change it againg and fix that,
should i use fully synthetic ? 75-90 if i dont remember wrong ? what to use in rear, i looked on receipt and i got 75-90 there also, shouldnt that be 75-140 if im not wrong ? so i think i change rear againg whit right oil, fully synthetic there also ? and what brand is best, think i have amalie or something now, can i use castrol. mobil, valvoline, redline ?? wich is best. ?? 2004, 4x4, |
Good morning! I recommend AMSOIL. Let me know If I can help.
Here's something for you to print out and put in theglove box. All you need to know about what and how much. 2004 FORD TRUCKS F250 HD PICKUP 6.0L 8-cyl Engine Code [P] Turbo Diesel LUBRICANTS & FLUIDS: Engine Oil Grade 1......CI-4+ SAE 15W-40 Synthetic Heavy Duty Diesel and Marine Motor Oil (AMEQT) SAE 15W-40 Synthetic Blend Diesel Oil (PCOQT) Synthetic 5W-40 Premium Diesel Oil (DEOQT) Series 3000 SAE 5W-30 Synthetic Heavy Duty Diesel Oil (HDDQT) -9 To 90F......10W-30 [1] -20 To 30F......5W-30, 5W-40 [2] -20 To 0F......0W-30 [2] above 10F......15W-40 [3] Manual Transmission,S6-650 W/O COOL......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Manual Transmission,S6-650 W/ COOL......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Automatic Transmission,TorqShift......MSP Low Viscosity Synthetic ATF (ATLQT) Automatic Transmission,4R100......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Limited Slip Differential, Rear Ford......GL-5* All TEMPS......75W-140 [4] [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Limited Slip Differential, Rear Dana 135......GL-5* All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Limited Slip Differential, Rear Dana 135......GL-5* All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Standard Differential, Rear Ford......GL-5 All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Standard Differential, Rear S110, S130......GL-5 All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Limited Slip Differential, Rear Dana 80......GL-5* All TEMPS......75W-90 [5] SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) 75W-90 Synthetic Long Life Gear Lube (FGRQT) SAE 80W-90 Synthetic Gear Lube (AGLQT) Differential, Front......GL-5 All TEMPS......90 SAE 80W-90 Synthetic Gear Lube (AGLQT) SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) 75W-90 Synthetic Long Life Gear Lube (FGRQT) SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT) Transfer Case,......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Torque-Drive Synthetic Transmission Fluid (ATD1G) Fluids Power Steering Fluid......MA Synthetic Universal Automatic Transmission Fluid (ATFQT) Power Steering Fluid......MA Torque-Drive Synthetic Transmission Fluid (ATD1G) Brake Fluid......HB AMSOIL Brake Fluid DOT-3 (BF3SN) Clutch Fluid......HB AMSOIL Brake Fluid DOT-3 (BF3SN) [1] Ford TSB 05-16-6 states that SAE 10W-30 is acceptable to use in operating temperatures from -1 °C (31 °F) to 32 °C (90 °F).SAE 10W-30 is the preferred viscosity if the operating varies from -20 °C (-4 °F) to -1 °C (31 °F). [2] Ford TSB 05-16-6 states that the shown viscosity is acceptable to use in the shown temperature range. [3] Ford TSB 05-16-6 states that SAE 15W-40 is acceptable to use in operating temperatures from -12 °C (11 °F) to -1 °C (31 °F). SAE 15W-40 is the preferred viscosity if the operating is above -1 °C (31 °F). [4] Synthetic oil is required. [5] Add 8 oz. (236 ml) of Additive Friction Modifier XL-3 or equivalent formulated to meet Ford Spec EST-M2C118-A for complete refill of limited slip axles. FILTERS: Oil Filter AMSOIL Ford 6 L Oil Filter (SDF88) Oil Filter P550528 Oil Filter Air Filter INJEN-AMSOIL Air Intake System (PF9050P) [1] Air Filter INJEN-AMSOIL Air Intake System (PF9049P) [2] Air Filter P603577 Power Core Air Filter [3] Air Filter [4] Air Filter WIX 49490 Air Filter [5] Air Filter WIX 42731 Air Filter [3] Cabin Air Filter Fuel Filter Fuel Filter for Ford 6.0L Diesel Powerstroke Applications (FFK60) Fuel Filter WIX 33899 Fuel Filter Transmission Filter WIX 58624 Auto Tran Filter [6] Transmission Filter WIX 57702 Auto Tran Filter [7] [1] INJEN Filter Kit With MAF Sensor [2] INJEN Filter Kit Without MAF Sensor [3] Std. Power Core Version [4] Flame Retardant version of 49490 [5] Can be used to replace Power Core element 42731 [6] 5R110W [7] By Element NGK PLUGS AND WIRESETS: No Recommendations WIPER BLADES: Blade Class Driver Passenger ExactFit T201 T201 NeoForm T16200 T16200 Winter T37205 T37205 CHASSIS LUBRICATION: 2WD 4-10 Fittings, 0 Plugs..........LM Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR) Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB) Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR) 4WD 0-7 Fittings, 0 Plugs..........LM Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR) Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB) Synthetic Water Resistant Lithium Complex Grease; NLGI #2 GC/LB (GWRCR) CAPACITIES: Engine, with filter..........15.1 quarts [1] Cooling System, Initial Fill..........27.5 quarts [2] AMSOIL Antifreeze and Engine Coolant Automatic Transmission, 4R100 Initial Fill..........6.5 quarts Automatic Transmission, 4R100 Initial Fill..........6.5 quarts Automatic Transmission, TorqShift Initial Fill..........7.6 quarts Automatic Transmission, Total Fill 4 speed 26 Plate 4R100..........17.7 quarts 4 speed 20 Plate 4R100..........17.1 quarts 5 speed TorqShift..........19.1 quarts Manual Transmission, 6-SPD W/O OCOOL..........11.7 pints Manual Transmission, 6-SPD W/ OCOOL..........12.7 pints Manual Transmission, 5-SPD ZF..........6.8 pints Manual Transmission, S6-650 W/ COOL..........12.7 pints Manual Transmission, S6-650 W/O COOL..........11.7 pints Differential, Dana 50 Front..........3.9 pints Differential, Dana 60 Front..........5.8 pints Differential, Dana 135 Rear..........23.3 pints Differential, Dana 80 Rear..........8.5 pints [3] Transfer Case, ..........4.1 pints [1] When refilling, remove dipstick to provide adequate venting and allow oil to flow into crankcase. [2] Includes heater and 5.0 qt (4.7L) in coolant recovery [3] Fill to no more than 1/4 to 9/16 inch below fill plug hole. TORQUES: Oil Drain Plug.....32 ft/lbs Manual Transmission ZF S6-650 Fill Plug 26 ft/lbs Drain Plug 26 ft/lbs Transfer Case NV271 Fill Plug 20 ft/lbs Drain Plug 20 ft/lbs |
thanks thats a good list, but now a stupid question how to know what i have on my truck ??
All TEMPS......90 SAE 80W-90 Synthetic Gear Lube (AGLQT) SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) 75W-90 Synthetic Long Life Gear Lube (FGRQT) SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT) You'll have to determine what you have in the rear. Start with the tag attached to the rear housing cover. Limited Slip Differential, Rear Ford......GL-5* All TEMPS......75W-140 [4] [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Limited Slip Differential, Rear Dana 135......GL-5* All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Limited Slip Differential, Rear Dana 135......GL-5* All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Standard Differential, Rear Ford......GL-5 All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Standard Differential, Rear S110, S130......GL-5 All TEMPS......75W-140 [5] SEVERE GEAR 75W-140 Synthetic EP Lubricant (SVOQT) 80W-140 Synthetic Long Life Gear Lube (FGO05) Limited Slip Differential, Rear Dana 80......GL-5* All TEMPS......75W-90 [5] SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT) 75W-90 Synthetic Long Life Gear Lube (FGRQT) SAE 80W-90 Synthetic Gear Lube (AGLQT) |
said 75-140 on tag,
thanks for help, whats downside when i have wrong oil there ?` then what brand is good, can i use what i want here ?? |
i had 75w 90 in my rear for a few months by accident, its fine, but if you do alot of long distance high way driving or tow with it, you should change to 75w140 because it handles the heat better. have to keep in mind that with the rear axle, the differential fluid also lubricates your wheel bearings unlike the front axle.
![]() ![]() You asked. Rumors have it FORD may start using AMSOIL from the factory. Would be a complete departure from what AMSOIL has always supported - small business.
Last week I changed both front and rear differentials with Schaeffer's 75W-140.
how about castrol oils, its easy for me to get,
amsoil they dont have here. |
