OK WHAT ELSE - Ford Powerstroke Diesel Forum
Old 06-18-2010, 12:46 PM
OK WHAT ELSE
OK now that I have the intake off I am going to remove the EGR cooler and oil cooler. I will replace the EGR with a bullet proof one, however I am still debating on the bulletprooof oil cooler. Whadda yall think? I REALLY HATE t do this twice.. I have installed a coolant bypass fillter so I am still up in the air.
Anyway, looking to see what everyone thinks I should do while I am in this far. HS and HG probably wont happen as I need to finish building my shop, then I can get a lift to lift the cab and do it right. So beyond the EGR and oil cooler, WHAT ELSE?
On a side note I am very dissapointed with my FORD dealer. I was missing a bolt out of the turbo (laying in the valley).
Also wich hose should I have off the egr cooler? mine is blue and I thought the better one was oragne, am I wrong?
I have the luxury of spending time with my truck down, so I am taking my time with this. It took me about 4 hours to get to the EGR and oil cooler so I think I am doing well.
LETS HERE YOUR INPUT!!!!!!!!!!!!!!
Old 06-18-2010, 01:30 PM
WELL went aghead and ordered the whole Bulletproof kit forom gene soooooo..... arggg man its expensive. If I never have to do this again it will be worth it so here goes!!!!!!!!!!
Old 06-18-2010, 01:36 PM
Air Assault!!
Send a message via AIM to MPTonyT
I would upgrade the CST fitting on the HPOP while you have it that far apart. Do a search you should be able to find the Ford upgraded part number.
Edit: FORD PART #4C3Z-9B246-D
Old 06-18-2010, 02:08 PM
Ordered that through Gene too!
