Seat Belt -- how to eliminate beeping noise... - Ford Powerstroke Diesel Forum
Old 06-18-2010, 04:14 AM
Is there a way I can turn the beeping noise off when not wearing a seat belt while operating the truck??
Notice I said "operating" vs. "driving", as I will of course wear while driving. However I need this off for times when I am at the ramp launching the boat or casual driving off the highway/local roads; like in the woods or on a farm.
Thanks for any info.
Old 06-18-2010, 04:26 AM
Lt. Negativity
Look in your manual should show you a way to turn off the chime.
Old 06-18-2010, 05:32 AM
Just reach under the seat and unplug the seat belt alarm plug, then it will never chime again. If i remember correctly it can be seen from the rear of the seat just underneath. That's how I did mine, problem eliminated.
Old 06-18-2010, 08:01 AM
The manual procedure didnt work for mine. So I just unplugged it.
Old 06-18-2010, 08:05 AM
X3 on the unplug, now if I could just listen to music with the doors open!
Old 06-18-2010, 08:42 AM
Air Assault!!
Send a message via AIM to MPTonyT
You can't listen to music with the doors open? weird.
Old 06-18-2010, 08:48 AM
I think he is talking about the open door ding. I took my tumbler out and taped one of the "tabs" so it wouldn't ding when the doors are open.
Old 06-18-2010, 12:09 PM
06powerstroke06;
With all those Ford PSd's you have in the signature pic, how many had a bad oil cooler that needed replaced OR have had the EGR delete?
Just curious...
Old 06-18-2010, 04:57 PM
Deactivating/Activating
Turn the ignition switch to the RUN position. (Do not start the engine.)[/ol]
Wait until the safety belt warning lamp turns off (approximately 1 to 2 minutes).[/ol]
3. NOTE: Steps 3 must be completed within 50 seconds after the safety belt warning indicator turns off.
For seating position being disabled, at a moderate speed, buckle then unbuckle the safety belt 9 times, ending with the safety belt in the unbuckled state. After this step, the air bar warning indicator illuminates for 3 seconds.
Within 10 seconds after the air bar warning indicator turns off, at a moderate speed, buckle then unbuckle the safety belt.
Old 06-18-2010, 06:05 PM
Originally Posted by Pathfinder22 View Post
06powerstroke06;
Just curious...
Lets see.... No replaced oil coolers, although The 07 might need it. Both 6.0s have EGR intact but tuned off.
