heat shield! - Ford Powerstroke Diesel Forum
Old 06-17-2010, 08:56 AM
heat shield!
so just bout a farm boys diesel 5 inch exhaust and it is rattling like crazy! because for some odd reason there isnt any of that mesh heat shield in one spot under the floor board so it just hits it continuisly!!!!!!!!!!!! any body kow where i can find some!!!! everytime i drive my truck i just get pissed its so annoying i have tried to fix it numerous times
Old 06-17-2010, 10:40 AM
Can you adjust the mounts so it has more clearance? This is why I wouldn't go larger than 4", no performance benefit either.
Old 06-17-2010, 11:07 AM
Chapter Director
Seems strange that it was not included. I would give Farm Boys a call, they might give you what you need for free.
Old 06-17-2010, 05:31 PM
fyi cart, its not 5 inch until after the cat delete. therefore size isnt an issue. i have continusly tried adjusting evry mount.
Old 06-17-2010, 05:35 PM
riddin' high
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
my 4"down pipe to 5" straight pipe dont even come close to touching anywhere, it was hard to get in tho
Old 06-17-2010, 05:54 PM
Ok, you didn't specify where it was that tight, so I assumed it was on the 5" part. Usually there's not much problem with the 3.5" downpipes, are you sure everything is connected and hanging properly?
Old 06-17-2010, 07:24 PM
yes i have completley taken the exhaust off except the down pipe
