Warranty. Starting not to care.. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-16-2010, 03:44 AM Thread Starter
Marsh68's Avatar
I've been holding off the EGR delete so I wouldn't scrub my powertrain warranty. I have 2yrs/35k miles left. My main concern was getting the heads repaired if the gaskets went. But after talking with a Ford tech, I may not even worry about it. He says if Ford has to do the heads, they use new head "bolts" not the ARP studs to install the heads. To me, that puts me right back into the same situation.
I know there's other problems to worry about, but that is the priciest fix I know of.
I guess my question is, should I do the delete and not worry about the warranty or just wait until it runs out???
My truck is completely stock 07 CC with 65k miles. Purchased it 2 months ago.
Marsh68 is offline
post #2 of 7 Old 06-16-2010, 04:46 AM
When my head gaskets went, I bought the ARPs from the dealer, and they installed them instead of the bolts. If your dealer will do that, it won't mess with warranty because ARPs obviously didn't cause a problem. EGR delete is another story - I'll be waiting for my warranty to end before I go there.
2013 F250 CC/SWB Lariat FX4
325/60/20 Nitto Terra Grapplers
NOBAMA!!
Is it just me, or does it seem like all Dodge drivers are A$$holes?
jdalhaus is offline
post #3 of 7 Old 06-16-2010, 05:15 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Depends on the dealer here. Many will install the ARP studs when the do head gaskets but that will void warranty support for the head gaskets technically. If you have a mod friendly dealer they probably wouldn't but it could happen if Ford sends a rep out to take a look. Same with the EGR delete. You really have to look around and find a mod friendly dealer though.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 7 Old 06-16-2010, 05:42 AM
jetjock15's Avatar
Quoted: 113 Post(s)
im same as you, my truck only has 22k miles on it and 2 years left on the 5 yr part.... im so ready for egr delete, studs, new turbo and injectors etc.... im looking for a mod friendly dealer, im just about ready to forget about warrenty and build a bulletproof engine
King/Deavers/37s/AF 22x12s/4:56/F/R Detroits/Road Armors/Warn12k/155/30s, MTW S1Billet/GoGo Manifold/Banks IC/NADP Heavy Hauler Trans/ORU Hydro-Steer/PHP tow Tune/BPD HD oil cooler/Oil & Coolant bypass/AMP steps/TransferFlow tank-toolbox
jetjock15 is offline
post #5 of 7 Old 06-16-2010, 07:39 AM
xjeeper's Avatar
When I was still on warranty, I ran an aluminum plug purchased on Ebay for about $70. this at least kept any coolant from an EGR cooler failure from getting into the intake and blowing the head gaskets. The original EGR valve could be reinstalled in about 10 mins if I had to visit the dealer. On 03/ 04 remove the blade from the intake butterfly as well, also takes only about 10 mins. If I have any failure in the future, or when I install any additional upgrades I will install the neal industries EGR cooler, retain the aluminum slug in place of the EGR valve, and weld a restrictor into the up pipe(a steel plug with a small hole drilled into the center to restrict, but not completely cut off exhaust flow to the EGR system. Do not kid yourselves stricter emmissions inspections are coming nationwide. A full delete will be a dead give away on a visual inspection.
xjeeper is offline
post #6 of 7 Old 06-16-2010, 07:54 AM
kingranch89's Avatar
my dealer did arp studs an egr delete for me when they pulled the cab to do the head gaskets you just gotta make friends at the stealership
2007 F250 king ranch 6.0 powerstroke
SCT w/ custom tunes from innovative
5" mbrp exhaust
Studded and EGR Deleted
FINALLY SOLD!!!!
on to the next toy
kingranch89 is offline
post #7 of 7 Old 06-16-2010, 08:07 AM
If your only mod is an EGR delete, why are you worrying about the head gaskets failing? I could not tell from your post or sig if you run a tuner or not but if your stock, drive it and enjoy it. 6.0 head gaskets are not a ticking time bomb.
2003 (12/02 build) F250 6.0 4X4 Crew Cab,190,000, all original
Repaired under waranty:Y-pipe, ICP, reflash
Repaired by me: ICP, FICM, cracked degass bottle, CAC boots, rear diff seal, overhead console, Blue spring w/O-ring
Bypass oil+coolant filters, in-line PS filter. T-5 10w30 every 7,500 mi.
Guages: Boost, Pyro and Trans, ScanGaugeII
Loubell is offline
