how do you gut a cat??
about to take my cat off wondering how to gut it.. is there anything in there i need to leave??
also a friend told me if i did it i need to remove the cables from the batteries for fifteen mins to reset my computer.. is that true?? |
I assume you're wanting to get rid of the flow restrictions caused by the cat. Cut the thing open, remove the catalyst material, weld the can back together.
When I gutted the cats on my Explorer I took a metal bar and started stabbing at the material thru the opening to break it apart. Every once in a while I would tip it over and empty out the loose material.
flex bit and a shop vac
long drill bit and a air chissel.
drill a bunch of holes thru the cat so there s path for the loose material to go. take a air chissel and start widdeling. dont need to leave anything. if u dotn hav access to air tools then a metal bar and a hammer will work but jus be prepared to work at it for a while. |
First you must kill the cat, then string it up by the back legs and cut down the mi....ohh. Nevermind. I would just get a crow bar and jab it through the middle.
Piece of pipe 3-4 ft. A hammer and about 30-45 mins. Be careful not mess up the slip joints...
having problems getting the cat off the connection between it and the muffler.. ive taken alot of crap apart trying to get an angle on it so i can pull.. but it stuck like a mug. i think im just gonna start jabbing at it with my long drill bit and hope i can shop vac everything out.. if anyone has and tips for getting it lose please let me know
you need a drill, rebar and chain and weld a 3 inch piece of chain to end of rebar put other end in dril and go to town
funny man ha ha
