brake problems - Ford Powerstroke Diesel Forum
Old 06-12-2010, 09:52 PM
brake problems
well i changed my back brakes and my passenger rear rotor. (my passenger rear brakes where metal on rotor) now my rear passenger makes noise when i drive but i dont see any brake dust or smell anything or feel much heat coming off the tire/wheel. but the other side where i just replaced the brakes now its smelling really bad and getting very hot in short distances but i dont see any brake dust.
Old 06-12-2010, 10:08 PM
You Guys! Im Seriously!
Sticking caliper
It may be a sticking caliper, next time it does it jack the wheel up and see if it is hard to spin. If so check to be sure the pressure is releasing from the caliper, if it is then either rebuild or replace the caliper. If pressure is not releasing it could be a problem with clogged line.
Old 06-13-2010, 07:01 AM
jack it up and put it in neutral and spin it? how can i tell if the fluid is sucking back out or if its a caliper problem.. and if its the parking brake omg i dont know if i can get my freakin rotor off without damaging it lol
Thanks guys i know ive posted alot of stuff on here
Old 06-13-2010, 08:25 AM
Well to check if pressure is releasing stick a small clear line over the bleader (keep air from getting back in) crock the bleader open and if fluid soots ou very hard or of the wheel frees up then its a line or pressure problem somewhere. If wheel stays locked remove the caliper and if still locked then suspect the parking brake (unlikely if you didnt adjust it but possible) If you give me the make and model of your truck i can scan and email the chiltons instructions. otherwise if you dont have this resolved by next weekend I will go pull the back rotor off my truck and take pics and show you how to do everything step by step
Old 06-13-2010, 02:10 PM
im about to go give it a shot.. its a 06 f350 supercab
