Originally Posted by 04GrayPowerStroke
What are the symptoms of it?
What causes it?
How do you get rid of it?
Thanks!!!!
Well i have never had the problem so this is just my thought. It goes into a limp mod to keep it from self destruct, like going into an idle mod and no power, running to hot ECT-EOT trans, no boost bad turbo just a few and if you have tunes (Hypertech Max Energy Stage 3) this may be part of it, i have no idea what it is but the 6.0 is already max out on HP and when you add more you better have deep pockets for, ARP studs,HG, and a lot more. Mine has all the power i need so i did mods to try and not have a problem by adding gauges to keep an eye on things and add a oil by-pass to keep the injectors clean, coolent filter to keep the oil cooler clean. I may be all wrong but i'm to old to change. You need to go to a dealer or shop to get rid of it.
2 stroker
