06 high idle mod - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-06-2010, 12:46 PM Thread Starter
06 high idle mod
ju st done the high idle mod on my 06 f350. i dont have upfitter swicthes . just connect to the purple w/light grenn stripe butt end wire over to a toggle switch ($6 at napa) then to 12volts. i slipped a wire under the #5 fuse in the fuse box to get my 12v. the purple/green wire is labeled BCP .there is a lot of info on here about this.hope this helps someone .i was at walmart today and saw a black rocker switch with a small indicator light that looks a lot cooler than my toggle switch ..ya might want to check it out at wally...
walleyecat is offline
post #2 of 4 Old 06-06-2010, 06:14 PM
thought the 06 has an automatic high idle, Mine kicks in around 3 to 5 min in Park.
06 F-350 Lairiat Chrome, 6.0, Smokey 1, EGR delete, Studded, str8 pipe, 2.5" level on 35's, bagged rear, bluespring, SCT custom tuned.
bfrd22 is offline
post #3 of 4 Old 06-07-2010, 03:45 AM
RZR007's Avatar
The automatic idle your taking about is different that the "high idle mod" you hear about on here. If its below a set ambient temp you truck will idle up to warm its self up. But I think it only revs up to 800-1000 rpms. Where is the PTO high idle revs up to 1200.
RZR007 is offline
post #4 of 4 Old 06-07-2010, 02:43 PM Thread Starter
i think also if its summer and your engine is at temp it wont idle up by itself..that's when the high idle mod is handy , remember 6.0 does'nt need to idle in excess...i try to idle about 3 min. before shut down to let turbo spool down...
