summer driving?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-05-2010, 05:42 PM Thread Starter
corbzy's Avatar
summer driving??
Hey everyone heading on a trip back home for some holidays and got just under 2500 kms to drive... anything i should do or check mainly on the truck before and or during the trip.... my buddy was saying something that you should idle the truck down for 5 mins when stopped after driving say 400 kms or so? is this true? will it possibly crack the turbo... sorry for all the questions this is my first diesel and am trying to learn more about it thanks for your time everyone!
corbzy is offline
post #2 of 12 Old 06-05-2010, 10:22 PM
510guy's Avatar
Quoted: 13 Post(s)
the guy who builds our turbo race car engines will idle for ten minutes after towing the race trailer to the track, we also do it with the car when it comes off the track. the turbo spins at a high rpm, still spinning when you shut it off but with no oil. let it idle and the oil cools down and the turbo cools and everyone is happy. the same as you shouldnt start cold and go towing or for big boost as the engine needs to warm up.
2006 F350 Crew Cab Dually 6.0 PSD 6 spd, ARP, IPR Gen 2 with up pipe, BD Diesel boot kit with metal cold side intercooler tube
2008 f350 Reg cab SRW flat deck 5.4l for work
510guy is offline
post #3 of 12 Old 06-06-2010, 08:42 AM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
I let it cool down to 350* before shutting the truck off
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #4 of 12 Old 06-06-2010, 10:21 AM Thread Starter
corbzy's Avatar
so i should after driving for 300 or 400 kms let it idle while i fill up at the gas station too.. or even pull off to the side let it idle down for 10 mins then go get the gas and be able to shut my truck off
corbzy is offline
post #5 of 12 Old 06-06-2010, 10:27 AM
Harleystroked_3310's Avatar
I don't think I would let it run while you pump. Some people do, I just don't think its a good idea. I always let the truck cool down at the pump, shut it off and then fill her up.
I am sure some people will say it will be fine, I just don't like to do it.
2005 F350 Harley Davidson Edition
SCT X3 w/Custom Tunes by Blankenship Tuning
Edge Insight w/EGT Probe
ARP Head Studs
Black Onyx Head & Exhaust Gaskets
Sinister EGR Delete Kit
Fresh Oil Cooler
DieselSite.com Coolant Filter
CAI
4in turbo back exhaust
Ford's Upgraded Fuel Pressure Regulator Kit & Banjo Bolts
Upgraded Oil Feed & Drain Tubes
Zoodad Mod
Built Tranny
10000K HID's
Harleystroked_3310 is offline
post #6 of 12 Old 06-06-2010, 10:55 AM
Fantom's Avatar
Quoted: 12 Post(s)
Really it only needs a minute or so to cool down. By the time I pull into the drive way, I'm under 400*
I never really let the truck idle for more than a few minutes, from what I've heard the 6-liter shouldn't be left to idle for long periods of time. So I always shut it down when I'm fueling.
John
100,000 Miles
Fantom is offline
post #7 of 12 Old 06-06-2010, 10:58 AM
i always just let it run while i fill up. Diesel fumes are not as flamable as gasoline so i dont worry about a fire with it. As far as a cool down before you shut it off you really do neeed to let it cool down but only for about 2-3 minutes. like the poster above said if you got gauges then let it cool to 350
2011 f250 6.7
Straight piped
SCT x4 custum tuned
Deleated
gtnit is offline
post #8 of 12 Old 06-06-2010, 11:22 AM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I try not to idle while fueling, because some guy is fueling gas next to me. (not that I never do mind you)
I try to ease off the freeway or road to the service stations, and don't mind waiting in line to let Her idle down. If I'm pulling my trailer, I usually pop the hood and check things and let engine compartment have some fresh air. I don't have an EGT gauge, so I let her cool a couple minutes to lower temp.
Around town, I just idle through parking lots and the neighborhood when I get home. Cools off pretty good.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #9 of 12 Old 06-06-2010, 03:00 PM
Special K's Avatar
You guys are refering too the EGT temps? For cool down right?
Special K is offline
post #10 of 12 Old 06-06-2010, 03:08 PM
Excurvelle's Avatar
Quoted: 3 Post(s)
Even with a gasser after a long towing pull I let it cool down, the problem I have found is the coolant temps really rise when shutting off a engine that has been working hard and can cause the system to puke, the turbo is just another factor with a diesel.
Excurvelle is offline
