Egr Delete - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-05-2010, 04:20 PM Thread Starter
RanchStroke's Avatar
Egr Delete
I just had my EGR Deleted and was wondering for all of you which have had this done. What was the difference in egt's after? I have an 06 CC and before the delete with the converter deleted egt's would be at about 750 on flat land about 70mph and with the converter on about 100 degrees hotter. After the delete and also converter deleted it is now running about 850.
Thanks
RanchStroke is offline
post #2 of 5 Old 06-06-2010, 07:04 AM
bfrank81's Avatar
From all of the reading that I have been doing about this EGR delete procedure it should make the EGTs cooler. Maybe I'm reading the info incorrectly.
bfrank81 is offline
post #3 of 5 Old 06-06-2010, 05:58 PM Thread Starter
Thats what I was thinking but not true with mine not unless I have a issue elsewhere?
post #4 of 5 Old 06-07-2010, 02:50 PM
makes sense the cooler is for cooling the egt going threw the egr .
did you take out the scoop or replace the pipe?
blood is offline
post #5 of 5 Old 06-10-2010, 03:21 PM Thread Starter
Replaced pipe
