Turbo Housing V-Band Clamp? - Ford Powerstroke Diesel Forum
Old 06-04-2010, 05:17 AM
Hey guys I was cleaning my turbo this week and when i put it back together i broke the v-band clamp that holds the 2 housings together, does anyone know a part number for this clamp?
Thanks in advance, Ben
Old 06-04-2010, 10:55 AM
Never mind found it.. W302676 is the V-Band Clamp, W302677 is the Lock Nut..
Old 06-04-2010, 12:05 PM
Slacker
Feedback Score: 4 reviews
Glad to hear it, Ben. Did you end up getting it put back together?
Old 06-04-2010, 01:25 PM
any problems that might be caused by that seal that goes on the housing where the v clamp is being pushed out around the housing???? i was driving down the road and heard a pop and loud hissing the v clamp broke and pushed the seal out i have oil on the housing im assuming its from the boost leak. i got a long trip tomorrow and cant get it fixed until i get back
Old 06-04-2010, 01:40 PM
Where in this picture is this leak? (hope this picture works)
Old 06-04-2010, 01:52 PM
compressor outlet where the v clamp holds the compressor housing to the y collector the v clamp broke and pushed the seal out but for some reason there oil all over the housing i drove about 400 miles before i pulled over to check it out it still builds boost but not as much because of the leak
Old 06-04-2010, 02:04 PM
Main issue would be where the oil is coming from. That clamp could be easy to replace, but the oil is different story.
Old 06-04-2010, 02:09 PM
where you getting these pictures these would be a big help when i get back home to fix things and i dont know where the oil is comin from i just noticed the housing covered in oil but i didnt notice oil anywhere else
Old 06-04-2010, 02:22 PM
From here:
Powerstroke 6.0L Technical Intro Manual
I HAVE to have pictures. Especially the ones that show where all the components are.
Good luck.
Old 06-04-2010, 04:31 PM
I got the turbo all cleaned up (thanks to the org) and got it all back together, I am just waiting on the clamp, the dealer didn't have one in stock so they had to order it, should be here monday..
