how to identify axle? - Ford Powerstroke Diesel Forum
Old 06-03-2010, 05:45 AM
I am getting ready to do gears and when I look up my truck there are a few different axles that it gives me? Is it stamped somewhere on the axle? Its an 04 F250 6.0L 4x4 auto if that helps. And also It has a 9" lift with 38's, do you think 4.30's would be good, only towing I do is a 21ft ski boat occasionally, thanks for any help
Old 06-03-2010, 06:14 AM
Should be on the door tag, driver side. Mine says D1.
Find yours and go here:
Super Duty And Heavy Duty: ______SUPER DUTY Tech Folder_____ - Ford Truck Enthusiasts Forums
Scroll down.
If still not sure, go to ford and have them print out a build sheet for your vin#
I don't know enough about gear ratios to answer your second question. Some one else might come along and help.
