Gauges - Ford Powerstroke Diesel Forum
Old 06-02-2010, 06:19 AM
Gauges
I have a question regarding gauges.I am currently in the process of adding ,boost,egt and trans for now,later on I plan on doing oil,fuel pressure and water temp.My question is what are most using electric gauges or mechanical. Thanks .Any help would be appreciated.
Old 06-02-2010, 06:25 AM
Air Assault!!
Send a message via AIM to MPTonyT
Trans and EGT are Electrical mostly and the Boost is Mechanical.
Old 06-02-2010, 06:34 AM
Have you looked at the "Edge Insight" (around $370 with the EGT probe?) Or maybe a "ScangaugeII" (around $169, but doesn't do EGT) Neither one does fuel pressure though.
Old 06-02-2010, 07:59 AM
I'm using both. I have a Diprocol Boost and EGT gauge on my pillar. I use the ScanGauge II for everything else, ECT, EOT, Trans, Volts, Etc...
Old 06-02-2010, 08:12 AM
all Temp gauges are electric... boost is mechanica and fuel pressure can be both but def go with electric.. you dont want to have to run fuel into the cab for a mech fuel pressure gauge...
like said above... i recommend the edge insight...
-Raul
Old 06-02-2010, 08:17 AM
Feedback Score: 9 reviews
I just snagged a used Insight w/ EGT probe for $185 shipped. Since the new ones are coming out you can find awesome deals on used ones. Mine is in perfect condition as well, and I got a painted pillar pod (happen to be the same color as my interior ) for $25 shipped!
I plan on getting a steering column pod, and filling it with a Dipricol fuel pressure gauge.
