Is there a method to test for fuel in oil? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-30-2010, 08:27 PM Thread Starter
In the last two days i drove 600 miles. I last checked the oil level 6 weeks ago after an oil change. It was, as always halfway between min and max on the dipstick. Today I checked it and had to drain 3 qts out to hit the mid between min and max!! I have a fumoto valve so the draining was no big deal. There is no milky color or foamyness so i am pretty sure no coolant got in the oil. is there a way to test for fuel in the oil? thanks
Jeeperman is offline
post #2 of 6 Old 05-30-2010, 09:06 PM
shhhhh, can you hear it?
08pwrstrokr6.4's Avatar
yea take a sample and find a diesel shop somewhere around you are ask the dealer if they do sample analysis.but at that level you could probably smell it
Patrick
TAPS Historian
08 6.4L ECSB
S&B intake,H&S Black Maxx,5" Pipe,Trac. Bars
13.77@100.63
OIF 07-08 16 months OIF 10/OND 10-11
Originally Posted by Diesel Tech Mag
All you need is a little knowledge,the right tools, and a buddy's truck to practice on.
08pwrstrokr6.4 is offline
post #3 of 6 Old 05-31-2010, 12:07 PM
You can go to any Halton shop (Cat Co.) and pick up a sample bottle about $20 bucks, prepaid pull the sample and send it in. If you have a prob. they will call in a week and if you have no prob. they will mail you there findings in about 2 weeks. I have been dealing with halton for over 30 years. With the added 3 qts in the oil it should be thinner and you should smell it.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #4 of 6 Old 05-31-2010, 12:21 PM
Other vehicle is an F250
Hank's Avatar
You might try putting a drop on a paper towel. Fuel will spread out and separate from the heavier oil which should stay in the middle. I've seen it work but an analysis is certainly the best way if you are not sure.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
post #5 of 6 Old 05-31-2010, 01:15 PM Thread Starter
thanks for the replies.. I just ordered a kit from blackstone and did the paper towel test. i definatly have two different colored rings on the paper towel. the outer ring is much lighter than the inner dark oil color. I guess its off to dealer for diagnoses. What do dealers charge to diagnose things? I just bought this truck in december and warranty is gone. It is an 05 F350.
post #6 of 6 Old 05-31-2010, 01:20 PM
probably their hrly rate which can be anywhere from 20-100 an hr plus any use of machines or equipment such as leak diagnosis fluid or the sorts.techs chime in...bump.
Patrick
TAPS Historian
08 6.4L ECSB
13.77@100.63
