HELP doing BB mod cant get last pipe back on
im almost done with the bb mod but the first pipe i took off i cant get it to fit all the way back on.. is there something special im suppose to do to get it on??
it looks like it puts oil on the top of the motor.. its a big pipe that says 12 NM torque i believe. its the big daddy pipe you see right behind the radiator |
you mean this one? The one that has red writing on it?
http://www.ford-trucks.com/forums/al...ictureid=29672 |
Picture's worth a 1,000 words...sounds like you're referring to your intake elbow. Loosen the band (hose) clamp completely...them warm it up using a heat gun or hair dryer...don't get crazy...just make the CAC boot a little more pliable....then work it back on starting from the bottom and stretch it over the intake elbow.
i cant get my phone pics to upload.. its the big momma jomma pipe i think we are all talking about the same pipe.. its the one with the words on it on the first guys pics.. the one with two clamps.. even though i only have one clamp
Follow what MOYOCK wrote. I have an 04, so mine is different from yours. I think. You must have an 05 or newer truck. Good luck!
And that pipe is part of your air intake, it comes out of your inter-cooler. |
ya its the intake elbow and its an 06 350
i hate this thing.. ive been working on it for hours.. even have my step son out there trying to help me. will this cause major problems if i tighen it without making it over that hump? or ridge or whatever you call it? |
yes if you don't get it on all the way it will blow off. I've found that you just need to push on it from the left side of the truck and kinda rock it side to side at the same time and it will go with a big pop.
You can do that, however its likely the boot will blow off during acceleration and scare the piss out of you.... If all else fails, try screwdrivers all around the pipe and pry against it.
Have you tried to heat it? Sounds like this tube is a PITA. Better to have it right, then to find out what it might cause later.
I have heard that it could also dent the hood. I have a King Ranch, wouldn't want to clean the leather after that!
