Coolant filter bypass???? - Ford Powerstroke Diesel Forum
Old 05-30-2010, 03:35 PM
I was talking to the technician at the shop that I am getting ready to take my truck to for an EGR delete, and he said that this mod is not necessary and not to waste my money on it. I would like to hear from you guys and maybe some other techs, and see what you think.
Old 05-30-2010, 05:16 PM
I have it on my engine. 2 filters so far. First one I changed at the 300 mile mark. A few table spoons in the filter. Let the next one go for 3000 miles, and found roughly 1-2 table spoons in the filter. I'm not cleaning the filters out very well though. I usually just turn them over and let stuff run out before opening.
I'm going to let the next filter go until it clogs, then will see what is in there.
Here is a picture of a clogged oil cooler. So, it's your choice, I'm glad I bought one.
Ford Truck Enthusiasts Forums - amdriven2liv's Album: Misc. pictures - Picture
Old 05-30-2010, 05:34 PM
Thanks brother, I just wanted to hear from people who did it. And if it is a good thing to do, or necessary.
Old 05-30-2010, 07:28 PM
What do I think....I think you should be talking to a different tech. He clearly should know about this issue by now if he knows anything about the 6.0L
Old 05-30-2010, 07:38 PM
See a different tech. It isnt necessary, by its good preventative maintenance.
Old 05-30-2010, 08:09 PM
In 500 miles mine had about 4 tablespoons of sand in it, if it is not the sand that pluges the cooler, what would?
2 stroker
Old 05-30-2010, 08:13 PM
Just imagine what its doing in the heads, etc over time.......
Old 05-31-2010, 01:23 PM
Thanks guys! I am going to do it, when he finishes with the EGR delete I will do the filter bypass myself.
Is it better to get the kits with the inlet/outlet valves on the filter head, or does it matter?
Old 05-31-2010, 01:34 PM
I have the valves, built them myself. I can turn the outlet off and see if it is still flowing into degas. Some have put a sight glass in the outlet hose to watch the coolant flow. Also, depending on location of install, it's cleaner for changing the filter.
Old 05-31-2010, 01:54 PM
If it aint a CAT itsa DOG
I have about 1500 miles on my kit and have changed my filter at 400m and at 1000m and both times a good about of nasty sand fell out of the filter. I also did not cut them open, but just turned em over. Its not necessary to have, but its well worth it. That amount of sand will do damage over time to waterpumps, radiators, heater cores, and the rest of the coolers.
